Schematic Review Request for Capacitive Soil Moisture Sensor
I recreated this based on standard capacitive soil moisture sensors on the market. I want to make my own as they are often poorly manufactured and have the wrong components. I've read a lot of different material on forums online, there is a lot of debate about different resistor values, etc. I will then connect this to whatever MCU I decide connecting, ground, 3v for power, and AOUT.
I'm a noob so please bare with me if I made any obvious mistakes. :slight_smile: I'm ready to learn, and greatly appreciate any feedback or suggestions.
The only issue I heard off with these sensors is a missing connection to R1, due to a manufacturing problem. Which is easily fixed.
Make sure you use the right (Cmos) “555”. A common 555 won’t work on 3volt
Leo..
  • C3 seems high.
I'm trying to find the best way to design a low cost high accuracy capacitive soil moisture sensor. I need to find a design that won't need to be fully tested and re-calibrated for every single different soil type. Something I can giveaway and the user only has to do simple calibration if necessary. The end project will have a ESP32 connected to it.
The majority of cheap capacitive soil moisture sensor out there use a TLC555. It works but due to low frequency it is more effected by salinity in the soil, causing it to need very specific calibration from what I've found.
Another option I've seen is using the MCU to generate a higher frequency and PWM. Like the chirp sensor: https://github.com/Miceuz/i2c-moisture-sensor/blob/master/README.md Or: https://github.com/ChococookieOS/pwm-moisture-sensor
I do wonder how the high frequencies would effect the other components on a compact board design. And how much they drift over time.
Any help is greatly appreciated! :slight_smile:
I have no idea about the salinity issue. But I do know that until you can eliminate the corrosion issue, what’s the point? The cheap resistive sensors last days to weeks, the better capacitive sensors might last a whole season or even a few years, but what I don't know is how the accuracy is changing over time as they slowly die.
Back in the day, when I had a big garden, I used timers. Each watering zone had its own settings to meet the needs of that zone. My ‘secret’ weapon, though, was to ‘sense’ the amount of natural rain using a weather station rainfall detector and then adjust the timers based on that. I never had a problem with it being too dry or too wet, and it never failed. It isn’t that hard a project either.
From my research it’s pretty simple to protect capacitive sensors to last for years with the right coatings. My main problem is I want it to be something I give away and the user doesn’t have to do much calibration on there end, just put in there plant pot and get the correct alerts. Perhaps the best way would be to take water, air, and take the average of the four most common houseplant soil mixes to use as the base values.
What elements do you think affects the reading?
Soil types, salinity, and soil volume may effect readings.
I have merged your forum topics due to them having too much overlap on the same subject matter @Aredunio.
In the future, please only create one topic for each distinct subject matter and be careful not to cause them to converge into parallel discussions.
The reason is that generating multiple forum topics on the same subject matter can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Thanks in advance for your cooperation.
