La libreria per l'SD è SD.h (qui allegata),
mentre il codice che uso è il seguente:
Grazie a tutti,
Tredipunta.
// **** INCLUDES *****
#include <TCN75A_Reader.h> // lettura di temperatura
#include <DS1307_Reader.h> // lettura di data e ora
#include <LowPower.h>
#include <Wire.h>
#include <SD.h>
// Istanze
LiquidCrystal_I2C lcd(0x27,16,2); //set the LCD address to 0x27 for a 16 chars and 2 line display
TCN75A classe_T;
DS1307 classe_D;
// Variabili
float cels;
float Tensione_0;
float Tensione_1;
String giorno;
String giorno_s;
String ora;
String ora_s;
// variabili in utilizzo per la scrittura su SD
File myFile;
String NomeFile;
char NomeFile_C[12];
// Initializing
// Classi
classe_T.TCN75A_init(72);
classe_D.DS1307_init(104);
// LCD
lcd.init();
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Initializing...");
// SD Card ***************************************
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(10)) {
Serial.println("initialization failed!");
// return;
else{
Serial.println("initialization done.");
classe_D.GetDate(&giorno, &ora, &giorno_s, &ora_s);
NomeFile =giorno + ".dat";
NomeFile.toCharArray(NomeFile_C, 12);
Serial.println("File Name:" + NomeFile);
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open(NomeFile_C, FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.println("Intestazione");
myFile.println("Intestazione");
// close the file:
myFile.close();
Serial.println("done.");
else {
// if the file didn't open, print an error:
Serial.println("error opening file");
// SD Card END -----------------------------------
// Enter power down state for 8 s with ADC and BOD module disabled
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
// Get values
classe_T.GetTemperature(&cels);
Tensione_0 = analogRead(0) * 5.0 / 1024.0 * 4.0;// da tarare in funzione del ripartitore di tensione
Tensione_1 = analogRead(1) * 5.0 / 1024.0 * 4.0;// da tarare in funzione del ripartitore di tensione
// Invio a porta seriale *************************
Serial.print(giorno_s + " ");
Serial.print(ora_s + " ");
Serial.println(cels,4);
// Invio a LCD ***********************************
lcd.clear();
//lcd.print("Time ");
//lcd.print(float(millis()/1000.0), 3);
lcd.print(ora);
lcd.setCursor(0, 1);
lcd.print("T");
lcd.print(cels, 4);
lcd.print(" V0");
lcd.print(Tensione_0, 1);
lcd.print(" V1");
lcd.print(Tensione_1, 1);
// Scrittura su file *****************************
File dataFile = SD.open(NomeFile_C, O_CREAT | O_WRITE | O_APPEND);
// if the file is available, write to it:
if (dataFile) {
dataFile.print(giorno + "_" + ora + "\t");
dataFile.print(float(millis()/1000.0), 3);
dataFile.print("\tTempDig\t");
dataFile.print(cels, 4);
dataFile.print("\tTensione_0\t");
dataFile.print(Tensione_0, 3);
dataFile.print("\tTensione_1\t");
dataFile.println(Tensione_1, 3);
dataFile.flush();
dataFile.close();
lcd.setCursor(7, 0);
lcd.print("-> OK");
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog");
lcd.print(" Error");
SD.zip (54.7 KB)
