void SaveGPIOsToSDcard(int RelayNumber, int GPIOoldState, int GPIOnewState){
SD.begin(5);
if(SD.exists("/Relay_GPIOs_States/states.txt")){
File StatesFile = SD.open("/Relay_GPIOs_States/states.txt", FILE_READ);
if(StatesFile){
String oldstr, updstr, StatesFileStr;
oldstr = "relay"+(String)RelayNumber+"="+(String)GPIOoldState;
updstr = "relay"+(String)RelayNumber+"="+(String)GPIOnewState;
StatesFileStr = GetStatesFileString();
//Open the states file in write mode and update the contents
SD.begin(5);
if (!SD.remove("/Relay_GPIOs_States/states.txt")){Serial.println("The old states file could not be deleted! GPIO states update failed!");
} else{
File StatesFile = SD.open("/Relay_GPIOs_States/states.txt", FILE_WRITE);
if (StatesFile){
StatesFileStr.replace(oldstr, updstr);
StatesFile.print(StatesFileStr);
StatesFile.close();} else{Serial.println("The old states file deleted but the updated one could not be created! GPIO states update failed!");}}
} else{Serial.println("The states file could not be opened for update initiation! GPIO states update failed!");}
} else{Serial.println("The states file could not be opened for update. Check SD card, directory or file availability! GPIO states update failed!");}
//SD card module CS pin
pinMode(5, OUTPUT);
The above is my code. When I try SaveGPIOsToSDcard (1, 1, 0);, it does NOT do anything. The file and path surly exist.
Any suggestions please?
Read the forum guidelines to see how to properly post code and some hints on how to get the most from this forum. Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
it is a good idea to put serial print every step of the way while you are debugging so that you can clearly see which part of the program run and which doesn’t.
Serial shows that the line if(SD.exists("/Relay_GPIOs_States/states.txt")) does not return true while file is there!
Has "SD.begin" or "file.read" a timeout?
Should I explicitly call "SD.end()" after each use of "SD.open()"?
This is the code I created (from other examples) to test out my SD card:
SD card read/write
Mod 01 make file name a string and iterate until we find a unused file name.
Mod 02 add capability to increment filename.
Rev 03 tested successfully on Arduino M0
SD card attached to SPI bus on ICSP Header.
SD Board power = 5V (for large board with EEPROM)
based on code created: Nov 2010 by David A. Mellis, 9 Apr 2012 by Tom Igoe
This code is in the public domain.
driver has a 512 byte buffer then write to SD
Closing the file forces any buffered data to be written to the SD and also updates
the file's directory entry.
If you don't close the file, you will lose all data written the file since it was opened,
not just the last buffer, since the directory entry will not be updated.
#include <SPI.h>
#include <SD.h>
// *** SD Card declarations **************************************************
#define SDCARD_CS_PIN 4
uint8_t fileNumb = 100;
char dataFile[8];
bool SD_Error = false;
File myFile; // create instance of a "File" class
SerialUSB.begin(115200);
delay (2000);
// Initializing SD card....
if (!SD.begin(SDCARD_CS_PIN))
{SerialUSB.print("initialization failed");
SD_Error = true;
// loop until we find a file that doesn't already exist.......
do
itoa(fileNumb, dataFile, 10); // (value, Array, base)
const char *extension = ".csv";
strcat(dataFile, extension); // syntax strcat(dest, source)
++fileNumb;
} while (SD.exists(dataFile));
SerialUSB.print("READY TO OPEN FILE FOR WRITING = ");
SerialUSB.println(dataFile);
myFile = SD.open(dataFile, FILE_WRITE); // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
SerialUSB.println(myFile);
// if the file opened okay, write to it:
if (myFile) {
myFile.println("data from boiler"); // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
SerialUSB.println("data from boiler");
//SerialUSB.print(" data written to file: ");
myFile.close(); // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
else {
// if the file didn't open, print an error:
SD_Error = true;
SerialUSB.print("SD_Error = ");
SerialUSB.print(SD_Error);
// nothing happens after setup
Results: READY TO OPEN FILE FOR WRITING = 100.csv
0
SD_Error = 1
My code writes some times and fails some times.
My SD test code results:
SD card type: SDHC
SD Card Size: 30000MB
Used space: 0MB
Remaining space: 30000MB
and my SD test code:
