SD card as a flashdrive
Hi everyone!
I am new to using the Arduino to interface an SD card, so I need help on this project. Is there a way to use the SD card as a FlashDrive? Is there a code out there to use the SD card as a USB flashdrive? Can I wire it up directly to the USB in such a way to have it work as a flashdrive? Thanks!
You can remove the SD card from the Arduino and put it into an SD card reader. The reader will then act as a USB FLASH Drive.
I didn't explain it well...My bad... I wanted to wire it on my own. I want to make my own SD card reader. I was wondering if I could do this directly to a USB with wires, or if I could use an Arduino to accomplish this. Sorry for not being clear!!
Zack_Johnston: I wanted to wire it on my own. I want to make my own SD card reader. I was wondering if I could do this directly to a USB with wires, or if I could use an Arduino to accomplish this. Sorry for not being clear!!
You can't wire an SD card directly to a USB cable.
It is theoretically possible to use an Arduino to allow a PC to read an SD card but it is far beyond a beginner project.
The only practical way for a PC to read an SD card as if it were a thumb drive is to use an SD card reader designed for that. They only cost about $10: http://www.frys.com/product/6547453
