SD card concerns; file format, odd file created, character encoding?
I am experimenting with the ReadWrite example provided with the SD card library. Code copied below.
I am getting odd results in Ubuntu. Sometimes I get extra directories and files created on the card (screen shot attached). The file names are like the text for the data file. This appears to happen at random?
When I double click to open the file in Ubuntu I get an error, suggesting that I am using the wrong character encoding? Is this a typical result and is it a problem? I can see the data I want, but also extra characters.
I want to be able to log to the SD card over weeks and then use the files as spreadsheet entires. At the moment I am testing the hardware and am not confident with these odd results. I have a SD card including on the Ethernet shield I am using.
  SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created   Nov 2010
 by David A. Mellis
 updated 2 Dec 2010
 by Tom Igoe
 This example code is in the public domain.
#include <SD.h>
File myFile;
  Serial.print("Initializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
   pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
	// close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
    	Serial.write(myFile.read());
    // close the file:
    myFile.close();
	// nothing happens after setup
