Hello everyone,
I am having a problem reading data that I am writing to a file on an SD card. I sent a small example but in the original project it will contain data that should be opened in MS Excel, and in the header it should contain the words "variável,cartão,número" but instead it is appearing "variável,cartão,número".
Please, could anyone tell me how I could fix this?
Thanks.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 10;
while (!Serial);
Serial.print("Initializing SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("1. is a card inserted?");
Serial.println("2. is your wiring correct?");
Serial.println("3. did you change the chipSelect pin to match your shield or module?");
Serial.println("Note: press reset or reopen this serial monitor after fixing your issue!");
while (true);
Serial.println("initialization done.");
File dataFile = SD.open("datalog.txt", FILE_WRITE);
if (dataFile) {
dataFile.println("variável,cartão,número");
dataFile.close();
else {
Serial.println("error opening datalog.txt");
delay(3000);
Following your suggestion, I managed to open the file correctly in two ways:
1-Making the conversion by Excel itself as you suggested;
2-Open the file in the notepad and save as UTF-8 BOM. When I do this the file opens correctly in Excel.
Now if it were possible to save the file already by Arduino, at least with this UTF8 BOM format, it would be good and not need to convert every time.
I tried your solution but what I had was just a file starting with the characters "ï» ¿". I saw that this in some versions of Excel can work or not. It didn't work for me. But your suggestion opened my mind to move on to another solution.
Searching for these characters here, I realized that I could simply convert the characters I need to byte. Then I found this site https://www.branah.com/unicode-converter that converts the characters I need to the corresponding byte. Then I just have to write it down.
jimLee,
I didn't quite understand your suggestion. In case I would just convert the character I need, is that it? That "something" in the case would be the byte to return?
Thank you Guys!
#include <SPI.h>
#include <SD.h>
File dataFile;
while (!Serial);
while (true);
String dataString = "variável;cartão;número";
unsigned char bom1[] = { 0x56, 0x61, 0x72, 0x69, 0xE1, 0x76, 0x65, 0x6C, 0x3b, 0x43, 0x61, 0x72, 0x74, 0xe3, 0x6f, 0x3b, 0x4e, 0xfa, 0x6d, 0x65, 0x72, 0x6f};
dataFile = SD.open("datalog.csv", FILE_WRITE);
if (dataFile) {
dataFile.print((char*)bom1);
dataFile.println("");
dataFile.close();
Serial.println(dataString);
else {
delay(3000);
