hello everyone I am trying to log data from a microcontroller to uno using uart (stm controller to Arduino UNO ) and I have interfaced the sd card module using spi and the problem I am facing currently is
I am able to create a file on the sd card and write data to it and when I check the sdcard a file is being created with particular size like 4kb or something and when I try to open the file and the see the data logged in it I find no data and the file is almost empty with no data found(at least garbage/unrecognized formats)
and below you can find my code
thankyou
#include
#include
int chipselect = 10;
File file;
if(!SD.begin(chipselect))
Serial.print("sdcard\n");
while(1);
Serial.print(" sdcard present\n");
/serial code/
//start
Serial.print("entered uart code\n");
while (Serial.available() == 0);
int val = Serial.read() ;
delay(10);
Serial.write(val);
Serial.print("exiting uart code\n");
//end
delay(40);
/sdcard code/
//start
File file = SD.open("STM12.dat",FILE_WRITE);
Serial.print("entered sd card code\n");
//delay(1);
if(file)
//delay(10);
Serial.print("created file\n");
while(file.available())
Serial.print("file is available for writing\n");
delay(10);
file.println(val,DEC);
delay(10);
Serial.print("typecasted and wrote the data to file\n");
delay(10);
file.close();
delay(10);
Serial.print("fileclosed\n");
delay(10);
Serial.print("exiting sd code\n");
delay(10);
Serial.print(file.read());
