Hello!! Everyone
I am using SDFat library to log data into memory card. My data length is of around 161 bytes with \n as delimiter.
I am logging at 2 logs per second, every things works fine for short duration.
I kept my device under test on 20:56:06,01/30/15 on Friday.
I works fine on Friday, then log was okay on Saturday and Sunday but it works for short time on Monday, the last correct reading value was at 02:39:28,02/02/15
After that i am getting junk values in my tex file.
My text file name is INT_001.txt, is there any limitation on the size of text files, the file size created is around 17MB, in this two days logging.
My SD Card writing is as follow:-
// set the current working directory for open() to Internal SD Card
intSD.chvol();
if (!myFile.open(filename, O_RDWR | O_CREAT | O_AT_END))
Serial.println("File Not Created or Opened");
// Using '\n' as delimiter
while(*buffer != '\n')
myFile.print(*buffer);
buffer++;
myFile.print('\n');
myFile.close(); // Close the file
Any Suggestion please.
