Hi All,
Very new to arduino and have been struggling with SD card reader. I'm trying to play an audio from the SD Card and get the "SD fail" everytime. I then tried the CardInfo.ino from SD Library and Quickstart.ino from SDFat Library to see if my SD Card is detected. In both, I always get error and Initialization fail.
Reformatted the card into FAT32, tried Windows format and the SD Card Formatter, and plugged back in. Quickstart still shows "initialization fail", but the interesting thing is
If you push the card in at the right moment after the "Initializing SD Card" prompt on the serial monitor, it can read. When you re-run the code with it already inserted, it wont.
and now I don't know what else to do as all the wiring is correct.
Things I've done :
- Made sure CS is correct (Pin 10)
- Tried 5V and 3.3V supply
- Tried 3 different SD Cards (2 x 32GB cards, 1 x 8GB card, all formatted FAT32)
- Tried different SD Card Formatter
SD Card reader I used are labeled XC4386, a pretty standard SD Card adapter module, and a 8GB SD Card I have lying around.
Any help would be appreciated. Thanks!
Edit:
Here's the connection diagram
and the code is basically example codes from library of SDFat and Built in SD.
Here's the CardInfo.ino
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created 28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 10;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
while (1);
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.print("Card type: ");
switch (card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
while (1);
Serial.print("Clusters: ");
Serial.println(volume.clusterCount());
Serial.print("Blocks x Cluster: ");
Serial.println(volume.blocksPerCluster());
Serial.print("Total Blocks: ");
Serial.println(volume.blocksPerCluster() * volume.clusterCount());
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("Volume type is: FAT");
Serial.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize /= 2; // SD card blocks are always 512 bytes (2 blocks are 1KB)
Serial.print("Volume size (Kb): ");
Serial.println(volumesize);
Serial.print("Volume size (Mb): ");
volumesize /= 1024;
Serial.print("Volume size (Gb): ");
Serial.println((float)volumesize / 1024.0);
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
the output of the Cardinfo.ino is this when it's pushed in at the right timing
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Clusters: 244224
Blocks x Cluster: 64
Total Blocks: 15630336
Volume type is: FAT32
Volume size (Kb): 7815168
Volume size (Mb): 7632
Volume size (Gb): 7.45
When it's left in and I rerun the code
Initializing SD card...initialization failed. Things to check:
and the SDFat QuickStart.ino
// Quick hardware test for SPI card access.
#include <SPI.h>
#include "SdFat.h"
#include "sdios.h"
// SD_FAT_TYPE = 0 for SdFat/File as defined in SdFatConfig.h,
// 1 for FAT16/FAT32, 2 for exFAT, 3 for FAT16/FAT32 and exFAT.
#define SD_FAT_TYPE 3
// Set DISABLE_CHIP_SELECT to disable a second SPI device.
// For example, with the Ethernet shield, set DISABLE_CHIP_SELECT
// to 10 to disable the Ethernet controller.
const int8_t DISABLE_CHIP_SELECT = -1;
// Test with reduced SPI speed for breadboards. SD_SCK_MHZ(4) will select
// the highest speed supported by the board that is not over 4 MHz.
// Change SPI_SPEED to SD_SCK_MHZ(50) for best performance.
#define SPI_SPEED SD_SCK_MHZ(4)
#if SD_FAT_TYPE == 0
SdFat sd;
File file;
#elif SD_FAT_TYPE == 1
SdFat32 sd;
File32 file;
#elif SD_FAT_TYPE == 2
SdExFat sd;
ExFile file;
#elif SD_FAT_TYPE == 3
SdFs sd;
FsFile file;
#else // SD_FAT_TYPE
#error Invalid SD_FAT_TYPE
#endif // SD_FAT_TYPE
// Serial streams
ArduinoOutStream cout(Serial);
// input buffer for line
char cinBuf[40];
ArduinoInStream cin(Serial, cinBuf, sizeof(cinBuf));
// SD card chip select
int chipSelect;
void cardOrSpeed() {
cout << F("Try another SD card or reduce the SPI bus speed.\n");
cout << F("Edit SPI_SPEED in this program to change it.\n");
void clearSerialInput() {
uint32_t m = micros();
do {
if (Serial.read() >= 0) {
m = micros();
} while (micros() - m < 10000);
void reformatMsg() {
cout << F("Try reformatting the card. For best results use\n");
cout << F("the SdFormatter program in SdFat/examples or download\n");
cout << F("and use SDFormatter from www.sdcard.org/downloads.\n");
// Wait for USB Serial
while (!Serial) {
yield();
cout << F("\nSPI pins:\n");
cout << F("MISO: ") << int(MISO) << endl;
cout << F("MOSI: ") << int(MOSI) << endl;
cout << F("SCK: ") << int(SCK) << endl;
cout << F("SS: ") << int(SS) << endl;
#ifdef SDCARD_SS_PIN
cout << F("SDCARD_SS_PIN: ") << int(SDCARD_SS_PIN) << endl;
#endif // SDCARD_SS_PIN
if (DISABLE_CHIP_SELECT < 0) {
cout << F(
"\nBe sure to edit DISABLE_CHIP_SELECT if you have\n"
"a second SPI device. For example, with the Ethernet\n"
"shield, DISABLE_CHIP_SELECT should be set to 10\n"
"to disable the Ethernet controller.\n");
cout << F(
"\nSD chip select is the key hardware option.\n"
"Common values are:\n"
"Arduino Ethernet shield, pin 4\n"
"Sparkfun SD shield, pin 8\n"
"Adafruit SD shields and modules, pin 10\n");
bool firstTry = true;
// Read any existing Serial data.
clearSerialInput();
if (!firstTry) {
cout << F("\nRestarting\n");
firstTry = false;
cout << F("\nEnter the chip select pin number: ");
while (!Serial.available()) {
yield();
cin.readline();
if (cin >> chipSelect) {
cout << chipSelect << endl;
cout << F("\nInvalid pin number\n");
return;
cout << F(
"\nAssuming the SD is the only SPI device.\n"
"Edit DISABLE_CHIP_SELECT to disable another device.\n");
cout << F("\nDisabling SPI device on pin ");
cout << int(DISABLE_CHIP_SELECT) << endl;
pinMode(DISABLE_CHIP_SELECT, OUTPUT);
digitalWrite(DISABLE_CHIP_SELECT, HIGH);
if (!sd.begin(chipSelect, SPI_SPEED)) {
if (sd.card()->errorCode()) {
cout << F(
"\nSD initialization failed.\n"
"Do not reformat the card!\n"
"Is the card correctly inserted?\n"
"Is chipSelect set to the correct value?\n"
"Does another SPI device need to be disabled?\n"
"Is there a wiring/soldering problem?\n");
cout << F("\nerrorCode: ") << hex << showbase;
cout << int(sd.card()->errorCode());
cout << F(", errorData: ") << int(sd.card()->errorData());
cout << dec << noshowbase << endl;
return;
cout << F("\nCard successfully initialized.\n");
if (sd.vol()->fatType() == 0) {
cout << F("Can't find a valid FAT16/FAT32 partition.\n");
reformatMsg();
return;
cout << F("Can't determine error type\n");
return;
cout << endl;
uint32_t size = sd.card()->sectorCount();
if (size == 0) {
cout << F("Can't determine the card size.\n");
cardOrSpeed();
return;
uint32_t sizeMB = 0.000512 * size + 0.5;
cout << F("Card size: ") << sizeMB;
cout << F(" MB (MB = 1,000,000 bytes)\n");
cout << endl;
cout << F("Volume is FAT") << int(sd.vol()->fatType());
cout << F(", Cluster size (bytes): ") << sd.vol()->bytesPerCluster();
cout << endl << endl;
cout << F("Files found (date time size name):\n");
sd.ls(LS_R | LS_DATE | LS_SIZE);
if ((sizeMB > 1100 && sd.vol()->sectorsPerCluster() < 64) ||
(sizeMB < 2200 && sd.vol()->fatType() == 32)) {
cout << F("\nThis card should be reformatted for best performance.\n");
cout << F("Use a cluster size of 32 KB for cards larger than 1 GB.\n");
cout << F("Only cards larger than 2 GB should be formatted FAT32.\n");
reformatMsg();
return;
// Read any extra Serial data.
clearSerialInput();
cout << F("\nSuccess! Type any character to restart.\n");
yield();
and this one just outputs
errorCode: 0x17, errorData: 0x1
Restarting
and my board is Arduino UNO, brand ELEGOO UNO R3
