When the GPS receive latitude and longitude information,
LCD display normal values??,
but to write to the SD card,
and then use the PC to read it,
sometimes it will show full data,
but it almost show me garbled characters.
#include <SD.h>
#include <Wire.h>
#include <TinyGPS.h> // Add to library folder
#include <string.h>
#include <SoftwareSerial.h>
File myFile;
LiquidCrystal_I2C lcd(0x27, 16, 2);
double d1,d2,gain,kp=0.1;
float flat, flon, x,y,lat2,long2,d3,d4,d5,d6,d7,a3,a4,a5,a6,a7,c,a1,b1;
char *pEnd;
TinyGPS gps;
SoftwareSerial nss(8, 255);// Yellow wire to pin 6
SoftwareSerial nano(4,3);
char value[20];
int i;
nano.begin(9600);
nss.begin(4800);
if (!SD.begin(10))
return;
lcd.init();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Waiting Target");
wait:
if(Serial.available()>0)
for(i=0;i<20;i++)
value[i] = Serial.read();
lcd.clear();
Serial.println(value);
char *pEnd;
d1=strtod(value,&pEnd);
d2=strtod(pEnd,NULL);
lcd.setCursor(0,0);
lcd.print(d1, 6);
lcd.setCursor(0,1);
lcd.print(d2, 6);
goto wait2;
//Serial.println('1');
goto wait;
wait2:delay(500);
lcd.clear();
//lcd.print("Reading GPS");
// Serial.println("Reading GPS");
bool newdata = false;
unsigned long start = millis();
while (millis() - start < 1000)
if (feedgps())
newdata = true;
if (newdata) {
gpsdump(gps); }
// Get and process GPS data
void gpsdump(TinyGPS &gps){
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
x=flat,y=flon;
Serial.print(x, 6); Serial.print(", ");
Serial.println(y, 6);
lcd.setCursor(0,0);
lcd.print(x, 6);
lcd.setCursor(0,1);
lcd.print(y, 6);
float course_to (float x, float y, float d1, float d2,float a1,float b1);
if ((d2-y)<0)
d3=(24-x)*111.11111*1000;
d4=(sqrt(sq(d1-x)+sq(d2-y)))*111.11111*1000;
d5=(sqrt(sq(d2-y)+sq(d1-24)))*111.11111*1000;
d6=((sq(d3)+sq(d4)-sq(d5))/(2*d3*d4));
d7=((acos(d6))*57.29578)*(-1);
d7=((acos(d6))*57.29578);
if((y-b1)<0)
a3=(24-a1)*111.11111*1000;
a4=(sqrt(sq(x-a1)+sq(y-b1)))*111.11111*1000;
a5=(sqrt(sq(y-b1)+sq(x-24)))*111.11111*1000;
a6=((sq(a3)+sq(a4)-sq(a5))/(2*a3*a4));
a7=((acos(a6))*57.29578)*(-1);
else if((y-b1)>0)
a7=((acos(a6))*57.29578);
a7=0;
c=a7-d7;
/* Serial.print(a1,5); Serial.print(", ");
Serial.println(b1,5);
Serial.print("Heading : ");
Serial.println(a7,5);
Serial.print("C-T angle : ");
Serial.println(d7,5); //cat to target angle
Serial.print("H-T : ");
Serial.println(c,5); //delta angle,H-T
Serial.print("C-T distance : ");
Serial.println(d4,2); //car to target distance
*/ a1=flat,b1=flon;
myFile=SD.open("gps.txt",FILE_WRITE);
if(myFile)
myFile.print(x,6);
myFile.print(',');
myFile.println(y,6);
delay(50);
if(d4<5)
nano.write('0');
goto done;
if(c<0)
c += 380;
Serial.println(c);
nano.write(c);
else if(c>0)
Serial.println(c);
nano.write(c);
gain=c*kp;
nano.write(gain);
delay(100);
done:delay(100);
// Feed data as it becomes available
bool feedgps(){
while (nss.available()) {
if (gps.encode(nss.read()))
return true;
return false;
