I have two shields, the SD card sheild and ethernet shield (With a micro SD card slot on the shield)
Is it possible to use both shields? The reason I'm asking is for two reasons...
The SD card shield supports full sized SD cards, which is what I will need for this project
The SD card also has some IO for expansion elsewhere for other SD cards or flash-like devices
However I'd still like to have ethernet capability, but the ethernet shield comes with a micro SD card port.
When I program using the SD card libraries, am I going to run into a problem as to which SD card / shield I can use?
SurferTim:
That SD shield is not Mega compatible. If you want to use it on a Mega, you must "pin bend" and jumper a few pins; D10, D11, D12, and D13. SD Card Shield V3.0 | Seeed Studio Wiki
If you use it on an Uno, you must "pin bend" and jumper D10 on the SD shield to another pin, like D4. D10 is the slave select for the w5100.
Excellent, this is a great start, thank you!
So in order to use the SD card shield on the Mega, I have to pin bend D10-13 to where on the Mega? by pin-bending you mean relocating the pins elsewhere correct? if that's the case, that's the SPI on the SD card shield, where would that be on the mega (At work so I don't have one readily available to look at)
and if I do choose to pin bend, do I have to tell the softwrae exactly where D10-13 are for the SD card library?
