SD Card with Atmega2560 Not working
I have this sd card schematic with Atmega2560 as the core.
And using this refference for mega pins
MISO = 50 / PB3
MOSI = 51 / PB2
SCK = 52 / PB1
SS = 53 / PB0
Is there anything wrong with my design? Because this isn't working.
Note that atmega2560 already installed arduino bootloader.
here i use example code :
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 53;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("\nInitializing SD card...");
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    while (1);
    Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("Card type:         ");
  switch (card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    while (1);
  Serial.print("Clusters:          ");
  Serial.println(volume.clusterCount());
  Serial.print("Blocks x Cluster:  ");
  Serial.println(volume.blocksPerCluster());
  Serial.print("Total Blocks:      ");
  Serial.println(volume.blocksPerCluster() * volume.clusterCount());
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("Volume type is:    FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize /= 2;                           // SD card blocks are always 512 bytes (2 blocks are 1KB)
  Serial.print("Volume size (Kb):  ");
  Serial.println(volumesize);
  Serial.print("Volume size (Mb):  ");
  volumesize /= 1024;
  Serial.print("Volume size (Gb):  ");
  Serial.println((float)volumesize / 1024.0);
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
The program working but Initialization SD Card Failed. *SD Card Inserted
Serial Monitor :
Initializing SD card...initialization failed. Things to check:
Any suggestion to help me solve this issue? Thank you.
Regards.
I've never used the Mega2560, but I don't see anything wrong with the schematic, except that I don't know what MP1-MP4 are on the microSD socket.
Does the 3.3V output of the regulator show any signs of sagging while running the sketch? Does the CS line go low during communications with the card? Is the card 32GB or smaller, formatted as FAT32?
Just grasping at straws here. Seems like it ought to work if the wiring is correct.
SD card Troubles with Arduino Mega - Using Arduino / Storage - Arduino Forum
Thanks mate. Might check my full schematic again if i miss something
