Hi everyody.
I'm newbie in Arduino and I meat problem with my new shield Neuftech Ethernet SD on Uno.
I'ved formated a 2Gb SD Card with software as said in the forum, and I use CardInfo sketch from example to test the shield.
But, when I start the board, it tells me that there's no card.
I've change CS pin from 4 to 10 without any success.
However, ethernet seems to work.
Is there specific SD library for this card, or maybe it is bad one (I'll retunr to sender if is).
Thank's a lot for help.
This is a new sketch used, lighter, for test :
//déclarations includes
#include <SD.h>
#include <SPI.h>
//Déclarations variables globales
File MonFichier;
//Déclarations des constantes globales
String NomFichier="toto.txt"; //8 caractères pour le nom, ext en 3, comme DOS
//déclarations fonctions
const int SDCS=10;
const int PinOther=4;
pinMode(PinOther,OUTPUT);
digitalWrite(PinOther, true);
//Initialisation système
if(!SD.begin(SDCS)) {//on utilise la broche 4 et on teste la comm
Serial.println("ERROR SD CARD");
return; // stoppe le programme
Serial.print("Communication OK !");
//Ouverture du fichier
MonFichier=SD.open(NomFichier,FILE_WRITE);
if (!MonFichier) {
//Erreur d'ouverture de fichier
return;
MonFichier.close();
//Boucle principale.
Nothing more than "Error SD Card".
I change the 2 const (SDCS and PinOther) between them, with no more success too.
I've red that sometimes power was wrong, so I put a 9V power supply without success too
The SD card slave select should be D4. The W5100 slave select should be D10.
Compile and upload this test code. After you upload the code, power down the Arduino for a few seconds, then power it up. Does the SD card start ok?
#include <SD.h>
#include <SPI.h>
const int ETHCS=10;
const int SDCS=4;
// disable W5100 SPI
pinMode(ETHCS,OUTPUT);
digitalWrite(ETHCS,HIGH);
else {
Serial.print("SD OK !");
Thanks for your answer.
I've done it, but still have SD card error
Hi !
I've just received my new Arduino Mega (an original, not a copy).
I've tried my sketchs with it, and there's no changes. Ethernet work good, but SD not.
I think, now, that my card is defective in SD part....
