SD initializing problem
hey guys
i am trying to figure out how to get this sd card shield working with arduino mega 1280. i have it all wired right with a breadboard i m 100% sure... the digital pins are 50,51,52,53....
so now the problem i m having is with the coding and the SD libraries....
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 50;
  Serial.print("\nInitializing SD card...");
  pinMode(53, OUTPUT);     // change this to 53 on a mega
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card is inserted?");
    Serial.println("* Is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
   Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch(card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  long volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
please help i need to get this done for a project i m doing....
i m basically making a temperature data logger....but i will be adding other sensors later....
this is the shield i m using
http://www.cutedigi.com/product_info.php?products_id=4435
The Slave Select (chip select) pin is 53 on the Mega, not 50.
const int chipSelect = 53;
I don't know about the card.init() function. I use
SD.begin(53);
Hey thanks for the reply but it still doesnt work...
any ideas?
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
  if (!SD.begin(chipSelect))
    return;
  switch(card.type())
    default:
    return;
  long volumesize;
  volumesize /= 1024;
  volumesize /= 1024;
void loop(void)
