Section 4.2 of Rev2
Hello,
I'm having this issue with the coordinate system on the whiteboard. After setting an initial position by measuring the strings of left and right. The calculated x and y where within a few millimeters off the actual distance. But, when I connect to hardware and start I move the robot upwards towards the top of the board (+motor speed). I then re-calculated the x and y, and the new x and y are incorrect. The initial x and y was about .2171x.2551m respectively. But, the new x,y came out to be .2045x.2621m. I should be about 0.220x0.110m(x,y).
How come the measurement are wrong? I checked the code in task 2 and everything is correct. Could someone further explain to me the coordinate system that is used in this project? I think I understand but there might be something I am missing.
Thanks,
Which kit?
This is about the Engineering Kit Rev 2. Regarding the first project, the drawing robot.
Post a drawing and the sketch.
