Seeed xiao esp32c3 blekeyboard not working
Hi everybody, i am Andrea and i am a mechanical engineer.
For my job i have developed a simple bluetooth keyboard using a esp32 wroom module.
The sketch started from a modified example of the library blekeyboard.h
I have tried to do the porting from the wroom to the tiny seeed xiao esp32c3 in order to have a very compact keyboard.
But the result is a not working situation both in bluetooth connection and also in serial checking for debugging.
I think i am loosing something about the coding on this device. Seems that it's necessary to do something more in the code because maybe the seeed behaves in a very different way compared to the wroom.
So the simple porting just changing the pinout it's not correct.
Can you please help me to understand how to workaround this?
Posting the schematics of Your build and the code would be good next step.
apologise for lot of italian comments
//PROGRAMMA PER TASTIERA BT PER OSMAND
//LA TASTIERA è LA ACUMA P5-BT CHE HA LA SEGUENTE SPECIFICA:
//LA TASTIERA è COMPOSTA DA 4 TASTI E DA UN MINIJOYSTICK PER FARE IL PAN E CON UNO SWITCH INTERNO SE VIENE PREMUTO IL JOYSTICK
//LA SOMMA TOTALE QUINDI DELLE FUNZIONI è DI 9 (4 TASTI, 4 DIREZIONI JOYSTICK, 1 SWITCH JOYSTICK), ECCO PERCHè QUINDI LA FUNZIONE KEYBOARD è IDEALE
//LA TASTIERA DEVE POTER CONTROLLARE OSMAND E LE ALTRE APP PER NAVIGARE CON IL ROADBOOK ELETTRONICO
//QUINDI SI RENDONO NECESSARIE 2 KEYMAP CHE DOVRANNO ESSERE SELEZIONATE TRAMITE LA PRESSIONE LUNGA DI UN TASTO:
//KEYMAP 0 --> OSMAND
//KEYMAP 1 --> ROADBOOK
//KEYMAP 0 - TABELLA CIFRAvsCARATTEREvsFUNZIONE:
//SHORT PRESS / CLICK
//1 --> VOL+ --> ZOOM+
//2 --> ARROW UP --> PAN UP
//3 --> D --> CHANGE MAP ORIENTATION
//4 --> ARROW LEFT --> PAN LEFT
//5 --> C --> CENTER POSITION
//6 --> ARROW RIGHT --> PAN RIGHT
//7 --> VOL- --> ZOOM-
//8 --> ARROW DOWN --> PAN DOWN
//9 --> NULL/NIENTE
//LONG PRESS / HOLD
//5 --> C --> CAMBIO MAPPA
//9 --> NULL/NIENTE
//KEYMAP 1 - TABELLA CIFRAvsCARATTEREvsFUNZIONE:
//1 --> ARROW UP --> SCROLL UP
//2 --> ARROW UP --> SCROLL UP
//3 --> VOL+ --> TRIP +
//4 --> ARROW LEFT --> NULL
//5 --> C --> NULL
//6 --> ARROW RIGHT --> NULL
//7 --> ARROW DOWN --> SCROLL DOWN
//8 --> ARROW DOWN --> SCROLL DOWN
//9 --> VOL- --> TRIP-
//LONG PRESS / HOLD
//si utilizza la libreria keypad per gestire in maniera efficace l'impiego di una tastiera semplice (in questo caso una 3x3)
//si utilizza la libreria BleKeyboard che serve per mandare i comandi corretti a osmand
//tasti direzionali --> pan
//vol +- --> zoom
//c--> ricentra la mappa
//d --> cambia orientamento
//serve poi fare la comunicazione BT tramite una libreria apposita
//i tasti direzionali vengono comandati da un joystick che a sua volta pilota dei transistor
//NB, non si fa uso di transistor, e a causa dello schema del joystick, siamo costretti a usare una tastiera 2x5 di cui però non verrà usato il carattere A
//PER INCLUDERE LA LIBREREIA BLE SI DEVE SCRIVERE COSI
#include <BleKeyboard.h>
BleKeyboard bleKeyboard("ACUMA_P5_01", "ACUMA", 100);
//INCLUSIONE LIBRERIA KEYPAD
#include <Keypad.h>
//GESTIONE LED RGB DI STATO
/******************** definizione delle costanti **********************************/
int portarossa = D7; // porta 11 da collegare all’anodo “rosso” del modulo RGB
int portaverde = D8; // porta 10 da collegare all’anodo “verde” del modulo RGB
int portablu = D9; // porta 9 da collegare all’anodo “blu” del modulo RBG
/**********************routine di accensione del led ********************************
  nelle prossime righe viene definita la routine “colore” che, al momento del lancio, e’
  accompagnata da tre variabili (rosso, verde e blu) che contengono i valori dell’intensita’
  luminosa, di volta in volta voluta, per ogni singolo led (0 = minim0a e 255 = massima) */
void colore (unsigned char rosso, unsigned char verde, unsigned char blu)
  analogWrite(portarossa, rosso); //attiva il led rosso con l’intensita’ definita nella variabile rosso
  analogWrite(portablu, blu); //attiva il led blu con l’intensita’ definita nella variabile blu
  analogWrite(portaverde, verde); //attiva il led verde con l’intensita’ definita nella variabile verde
//dichiaro il numero di righe e colonne della tastiera
const int nR = 2;
const int nC = 5;
//mappa dei caratteri che ci serviranno come riferimento per usare il costrutto "case"
const char acumaMap[nR][nC] =
  { '2', '8', '4', '6', '5'},
  { '1', '7', '3', '9', 'A'}
//definizione dei pin connessi alla keypad, devi usare byte perchè altrimenti non funziona
byte rowPin[nR] = {D0, D1};
byte colPin[nC] = {D2, D3, D4, D5, D6};
//costruzione della tastiera, la sintassi è questa. dove acumaP5 è il nome della tastiera e viene usata la mappa dei tasti
Keypad acumaP5 = Keypad( makeKeymap(acumaMap), rowPin, colPin, nR, nC );
unsigned long hold_time = millis();
// define time for a long press (ms)
const int long_press_time = 440;
const int long_press_repeat_interval = 160;
// Variable that holds the current active keymap
int current_keymap = 0;
// How many keymaps do we have?
const int KEYMAP_COUNT = 2;
void send_short_press(KeypadEvent key) {
  switch (key) {
    case '1':
      switch (current_keymap) {
        case 0: bleKeyboard.write(KEY_MEDIA_VOLUME_UP);
        case 1: bleKeyboard.write(KEY_MEDIA_PREVIOUS_TRACK);
    case '2':
        case 0: bleKeyboard.write(KEY_UP_ARROW);
    case '3':
        case 0: bleKeyboard.write('d');
        case 1: bleKeyboard.write(KEY_MEDIA_VOLUME_UP);
    case '4':
        case 0: bleKeyboard.write(KEY_LEFT_ARROW);
        case 1: bleKeyboard.write(KEY_LEFT_ARROW);
    case '5':
        case 0: bleKeyboard.write('c');
        case 1: bleKeyboard.write('c');
    case '6':
        case 0: bleKeyboard.write(KEY_RIGHT_ARROW);
        case 1: bleKeyboard.write(KEY_RIGHT_ARROW);
    case '7':
        case 0: bleKeyboard.write(KEY_MEDIA_VOLUME_DOWN);
        case 1: bleKeyboard.write(KEY_MEDIA_NEXT_TRACK);
    case '8':
        case 0: bleKeyboard.write(KEY_DOWN_ARROW);
    case '9':
        case 1: bleKeyboard.write(KEY_MEDIA_VOLUME_DOWN);
void send_long_press(KeypadEvent key) {
  Serial.println(key);
  switch (key) {
    case '1':
        case 0: send_repeating_key(KEY_MEDIA_VOLUME_UP);
        case 1: send_repeating_key(KEY_MEDIA_PREVIOUS_TRACK);
    case '2':
        case 0: send_repeating_key(KEY_UP_ARROW);
    case '3':
        case 1: send_repeating_key(KEY_MEDIA_VOLUME_UP);
    case '4':
        case 0: send_repeating_key(KEY_LEFT_ARROW);
        case 1: send_repeating_key(KEY_LEFT_ARROW);
    case '5': switch_keymap();
    case '6':
        case 0: send_repeating_key(KEY_RIGHT_ARROW);
        case 1: send_repeating_key(KEY_RIGHT_ARROW);
    case '7':
        case 0: send_repeating_key(KEY_MEDIA_VOLUME_DOWN);
        case 1: send_repeating_key(KEY_MEDIA_NEXT_TRACK);
    case '8':
        case 0: send_repeating_key(KEY_DOWN_ARROW);
    case '9':
        case 1: send_repeating_key(KEY_MEDIA_VOLUME_DOWN);
void send_repeating_key(uint8_t key) {
  while (acumaP5.getState() == HOLD) {
    bleKeyboard.write(key);
    delay(long_press_repeat_interval);
    acumaP5.getKey();
void send_repeating_key(const MediaKeyReport key) {
    acumaP5.getKey();
void keypad_handler(KeypadEvent key) {
  switch (acumaP5.getState()) {
    case PRESSED:
      send_short_press(key);
    case HOLD:
      send_long_press(key);
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
 // pinMode (12, OUTPUT);
  Serial.begin (9600);
  bleKeyboard.begin();
  acumaP5.addEventListener(keypad_handler); // Add an event listener for this keypad
  acumaP5.setHoldTime(long_press_time);
  pinMode(portarossa, OUTPUT); // dichiara la porta 11 come porta di output
  pinMode(portaverde, OUTPUT); // dichiara la porta 10 come porta di output
  pinMode(portablu, OUTPUT); // dichiara la porta 9 come porta di output
// the loop function runs over and over again forever
  acumaP5.getKey(); //key è la variabile a cui viene assegnato il numero della tastiera con l'istruzione getkey
  //delay(10);
  char key = acumaP5.getKey();
  Serial.println(key);  //se voglio stamparla sul serial monitor
  //Serial.println(acumaP5.getState());
  //gestione colori mappe
  if (bleKeyboard.isConnected()) {
      case 0: colore(0, 0, 255);
      case 1: colore(0, 255, 0);
  else {
    colore(255, 0, 0);
// This function cycles the keymap and signals the new keymap via the LED
void switch_keymap() {
  // Serial.println("Switching keymap");
  // cycle to next keymap
  current_keymap++;
  if (current_keymap > KEYMAP_COUNT - 1) {
    current_keymap = 0;
the error which came during the attempt of connection to the phone is:
also this simpler sketch, works properly in the base functions (keystrokes are visible in serial monitor) but the bluetooth connection is not working
/* @file CustomKeypad.pde
  || @version 1.0
  || @author Alexander Brevig
  || @contact alexanderbrevig@gmail.com
  || @description
  || | Demonstrates changing the keypad size and key values.
#include <Keypad.h>
const byte ROWS = 2; //four rows
const byte COLS = 5; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
byte rowPins[ROWS] = {D0, D1}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {D2, D3, D4, D5, D6}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
  char customKey = customKeypad.getKey();
  if (customKey) {
    Serial.println(customKey);
