Bluetooth Controller Kompilierungsprobleme
Board: ESP32 MiniKIT 2.0
Boardverwaltung: esp32 von Espressif System - 3.0.7
Bibliotheken: Bounce2 - 2.71.0
ESP32 BLE Keyboard von GitHub - T-vK/ESP32-BLE-Keyboard: Bluetooth LE Keyboard library for the ESP32 (Arduino IDE compatible)
Hi!
Folgendes Problem, ich möchte einen BT Controller zum steuern des Handys bauen.
Da es mehrere solcher Projekte gibt und ich noch nicht so weit bin meinen eigenen Code zu schreiben habe ich diesen hier benutzt:
//  Rally Controller for ESP32
//    Thomas Styles
//    Based on work by NordicRally
// Include Libraries
#include "esp_bt_main.h"
#include "esp_bt_device.h"
#include "esp_gap_bt_api.h"
#include <BleKeyboard.h>                                       // bleKeyboard
#include <Bounce2.h>                                           // Bounce
// Set Bluetooth Device Name
#define DeviceName "RCntrl P.1"
#define DeviceManufacturer "S.R.I."
#define BatteryLevel 69
BleKeyboard bleKeyboard(DeviceName, DeviceManufacturer, BatteryLevel);
  BleKeyboard bleKeyboard("Bluetooth Device Name", "Bluetooth Device Manufacturer", 100);
  BleKeyboard bleKeyboard("RControl v0.1", "S.R.I. NZ", 69);
  BleKeyboard bleKeyboard("BarButtons", "", 69);
  BleKeyboard bleKeyboard("CICTRL", "", 69);
  BleKeyboard bleKeyboard("DMD2 CTL 4K", ".", 100);
// Pinouts
  //NodeMCU-32S
  int Button1 = 17;
  int Button2 = 16;
  int Button3 = 25;
  int Button4 = 26;
// ESP32 DEVKITV1
int Button1 = 18;
int Button2 = 19;
int Button3 = 25;
int Button4 = 26;
  // MH-ET LIVE MiniKit for ESP32
  int Button1 = 27;
  int Button2 = 32;
  int Button3 = 33;
  int Button4 = 35;
// 0 to view all bonded devices addresses, 1 to remove
#define REMOVE_BONDED_DEVICES 0
// default 3, max 9
#define PAIR_MAX_DEVICES 9
// Buttons and position {0, 1, 2, 3}
#define NUM_BUTTONS 4
const uint8_t BUTTON_PINS[NUM_BUTTONS] = {Button1, Button2, Button3, Button4};
// BT Initialisation
bool initBluetooth() {
  if (!btStart()) {
    Serial.println("! Failed to initialise btStart !");
    return false;
  if (esp_bluedroid_init() != ESP_OK) {
    Serial.println("! Failed to initialise bluedroid !");
    return false;
  if (esp_bluedroid_enable() != ESP_OK) {
    Serial.println("! Failed to enable bluedroid !");
    return false;
  return true;
// Toggle Mode
BLEServer* pServer = NULL;
bool toggle_mode = false;
void Toggle_Name() {
  if (toggle_mode == 1) {
    esp_ble_gap_set_device_name("RCntrl P.2");
    pServer->startAdvertising();
    Serial.println("* Toggle Name Change to Profile 2 *");
    esp_ble_gap_set_device_name("RCntrl P.1");
    Serial.println("* Toggle Name Change to Profile 1 *");
// Format BT Device Addresses
uint8_t pairedDeviceBtAddr[PAIR_MAX_DEVICES][6];
char bda_str[18];
char *bda2str(const uint8_t* bda, char *str, size_t size) {
  if (bda == NULL || str == NULL || size < 18) {
    return NULL;
  sprintf(str, "%02x:%02x:%02x:%02x:%02x:%02x",
          bda[0], bda[1], bda[2], bda[3], bda[4], bda[5]);
  return str;
// Bounce config
Bounce * buttons = new Bounce[NUM_BUTTONS];
// Setup, runs once
  // Serial
  Serial.println("<! Starting Rally Controller !>");
  // bleKeyboard
  bleKeyboard.begin();
  Serial.println("< bleKeyboard Started >");
  // Set pullup mode and bounce interval in ms
  for (int i = 0; i < NUM_BUTTONS; i++) {
    buttons[i].attach( BUTTON_PINS[i] , INPUT_PULLUP  );
    buttons[i].interval(100);
  Serial.println("<! Rally Controller Started !>");
// Loop, runs constantly
  if ( (digitalRead(18) == LOW) && (digitalRead(26) == LOW) ) {
    delay(5000);
      toggle_mode = !toggle_mode;
      Serial.println("* Toggle Mode Status - " + (String)toggle_mode + " *");
      Toggle_Name();
  // Update the Bounce instance
    buttons[i].update();
  // bleKeyboard hold functions
  // Button 1
  if ((buttons[0].read() == LOW) && (toggle_mode == false) && (bleKeyboard.isConnected())) {
    Serial.println("+ - Profile 1");
    bleKeyboard.write('=');
    if ((buttons[0].read() == LOW) && (toggle_mode == true) && (bleKeyboard.isConnected())) {
      Serial.println("KEY_MEDIA_PREVIOUS_TRACK - Profile 2");
      bleKeyboard.write(KEY_MEDIA_PREVIOUS_TRACK);
  // Button 2
  if ((buttons[1].read() == LOW) && (toggle_mode == false) && (bleKeyboard.isConnected())) {
    Serial.println("- - Profile 1");
    bleKeyboard.write('-');
    if ((buttons[1].read() == LOW) && (toggle_mode == true) && (bleKeyboard.isConnected())) {
      Serial.println("KEY_MEDIA_NEXT_TRACK - Profile 2");
      bleKeyboard.write(KEY_MEDIA_NEXT_TRACK);
  // Button 3
  if ((buttons[2].fell()) && (toggle_mode == false) && (bleKeyboard.isConnected())) {
    Serial.println("R - Profile 1");
    bleKeyboard.write('r');
    if ((buttons[2].fell)() && (toggle_mode == true) && (bleKeyboard.isConnected())) {
      Serial.println("KEY_MEDIA_VOLUME_DOWN - Profile 2");
      bleKeyboard.write(KEY_MEDIA_VOLUME_DOWN);
  // Button 4
  if ((buttons[3].fell()) && (toggle_mode == false) && (bleKeyboard.isConnected())) {
    Serial.println("C - Profile 1");
    bleKeyboard.write('c');
    if ((buttons[3].fell()) && (toggle_mode == true) && (bleKeyboard.isConnected())) {
      Serial.println("KEY_MEDIA_VOLUME_UP - Profile 2");
      bleKeyboard.write(KEY_MEDIA_VOLUME_UP);
Nun meine ausgiebigen Fehlermeldungen:
C:\Users\kwark\Documents\Arduino\RC_test\RC_test.ino:58:43: warning: narrowing conversion of 'Button1' from 'int' to 'uint8_t' {aka 'unsigned char'} [-Wnarrowing]
   58 | const uint8_t BUTTON_PINS[NUM_BUTTONS] = {Button1, Button2, Button3, Button4};
C:\Users\kwark\Documents\Arduino\RC_test\RC_test.ino:58:52: warning: narrowing conversion of 'Button2' from 'int' to 'uint8_t' {aka 'unsigned char'} [-Wnarrowing]
C:\Users\kwark\Documents\Arduino\RC_test\RC_test.ino:58:61: warning: narrowing conversion of 'Button3' from 'int' to 'uint8_t' {aka 'unsigned char'} [-Wnarrowing]
C:\Users\kwark\Documents\Arduino\RC_test\RC_test.ino:58:70: warning: narrowing conversion of 'Button4' from 'int' to 'uint8_t' {aka 'unsigned char'} [-Wnarrowing]
In file included from c:\Users\kwark\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:16:
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32/include/driver/deprecated/driver/adc.h:19:2: warning: #warning "legacy adc driver is deprecated, please migrate to use esp_adc/adc_oneshot.h and esp_adc/adc_continuous.h for oneshot mode and continuous mode drivers respectively" [-Wcpp]
   19 | #warning "legacy adc driver is deprecated, please migrate to use esp_adc/adc_oneshot.h and esp_adc/adc_continuous.h for oneshot mode and continuous mode drivers respectively"
c:\Users\kwark\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp: In member function 'void BleKeyboard::begin()':
c:\Users\kwark\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:106:19: error: cannot convert 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'String'
  106 |   BLEDevice::init(deviceName);
      |                   std::string {aka std::__cxx11::basic_string<char>}
In file included from c:\Users\kwark\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:9:
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLEDevice.h:41:27: note:   initializing argument 1 of 'static void BLEDevice::init(String)'
   41 |   static void init(String deviceName);                                                            // Initialize the local BLE environment.
c:\Users\kwark\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:117:32: error: no matching function for call to 'BLECharacteristic::setValue(std::string&)'
  117 |   hid->manufacturer()->setValue(deviceManufacturer);
In file included from C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLEHIDDevice.h:17,
                 from c:\Users\kwark\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.h:24,
                 from c:\Users\kwark\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:1:
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:77:8: note: candidate: 'void BLECharacteristic::setValue(uint8_t*, size_t)'
   77 |   void setValue(uint8_t *data, size_t size);
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:77:8: note:   candidate expects 2 arguments, 1 provided
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:78:8: note: candidate: 'void BLECharacteristic::setValue(String)'
   78 |   void setValue(String value);
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:78:24: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'String'
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:79:8: note: candidate: 'void BLECharacteristic::setValue(uint16_t&)'
   79 |   void setValue(uint16_t &data16);
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:79:27: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint16_t&' {aka 'short unsigned int&'}
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:80:8: note: candidate: 'void BLECharacteristic::setValue(uint32_t&)'
   80 |   void setValue(uint32_t &data32);
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:80:27: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint32_t&' {aka 'long unsigned int&'}
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:81:8: note: candidate: 'void BLECharacteristic::setValue(int&)'
   81 |   void setValue(int &data32);
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:81:22: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'int&'
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:82:8: note: candidate: 'void BLECharacteristic::setValue(float&)'
   82 |   void setValue(float &data32);
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:82:24: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'float&'
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:83:8: note: candidate: 'void BLECharacteristic::setValue(double&)'
   83 |   void setValue(double &data64);
C:\Users\kwark\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\BLE\src/BLECharacteristic.h:83:25: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'double&'
exit status 1
Compilation error: exit status 1
Ich denke das ist ein Problem mit falschen Bibliotheken, habe aber noch zu wenig Ahnung.
Kann mir jemand helfen?
In den letzten Wochen haben wir in diesem Forum viele solche Fälle, weshalb ich mit einer alten Konstellation teste: IDE 1.8.19 und Core 2.0.17.
Damit erhalte ich nur Warnungen, die mit dieser Änderung verschwinden:
  uint8_t Button1 = 27;
  uint8_t Button2 = 32;
  uint8_t Button3 = 33;
  uint8_t Button4 = 35;
Der Sketch verwendet 1123905 Bytes (85%) des Programmspeicherplatzes. Das Maximum sind 1310720 Bytes.
Globale Variablen verwenden 39100 Bytes (11%) des dynamischen Speichers, 288580 Bytes für lokale Variablen verbleiben. Das Maximum sind 327680 Bytes.
Bei IDE und Core scheint viel geändert worden zu sein, da können die Bibliotheken häufig nicht so schnell folgen.
Es funktioniert, vielen Dank! :slightly_smiling_face:
Eigenartiger Weise gibt es jetzt aber Probleme mit der Micro USB Version, das USB-C Board funktioniert.
Manchmal lässt sich der Code hochladen, manchmal kommt eine Fehlermeldung:
A fatal error occurred: Invalid head of packet (0x48): Possible serial noise or corruption.
oder auch mal:
A fatal error occurred: Invalid head of packet (0x41): Possible serial noise or corruption.
Es gibt sehr, sehr viele Varianten! Da ich keine Glaskugel habe, weiß ich nicht, was auf Deinem Schreibtisch liegt.
Meine Spekulation: Das Datenkabel ist von schlechter Qualität.
Ich verwende einen USB-Hub mit eigenem Netzteil für eine zuverlässige Stromversorgung.
Es ist ein ESP32 MiniKIT V2.0 MH-ET-LIVE mit CH9102x Chip, eigentlich identisch mit der USB-C Version die ja funktioniert.
Seltsam ist halt das ab und zu mal funktioniert. Mit IDE 2.3.3 hatte ich nie Probleme. Habe verschiedene Kabel getestet.
Das deutet def. auf einen Wackelkontakt des USB-Kabel hin.
Bei Bauteilen immer Links posten, dann sehen wir es besser.
Lag nicht am Kabel, habe einen anderen Treiber installiert, jetzt klappt es.
Vielen Dank für die Hilfe!
Das passt irgendwie nicht.
Wenn der Treiber falsch ist, dann funktioniert es dauernd nicht.
Joa, was soll ich sagen... Hatte den http://www.wch.cn/downloads/CH343CDC_ZIP.html installiert und Probleme, jetzt CH343SER.ZIP - 南京沁恒微电子股份有限公司 und es funktioniert.
An den Kabeln kann es nicht liegen, da ich unter IDE 2.3.3 nie Probleme hatte und ich einige Kabel probiert habe.
Na dann ....
Anderes USB-Kabel probieren.
USB-Hub mit eigener Stromversorgung probieren
