The seeeduino is an arduino clone and has very similar specs.
* Microcontroller_ATmega168
* Operating Voltage5V/3.3V
* Input Voltage (recommended)7-12 V
* Input Voltage (limits)6-20 V
* Digital I/O Pins14 (of which 6 provide PWM output)
* Analog Input Pins8
* DC Current per I/O Pin40 mA
* DC Current for 3.3V Pin50 mA
* Flash Memory16 KB (of which 2 KB used by bootloader)
* SRAM1 KB
* EEPROM512 bytes
* Clock Speed__16 MHz
Just follow the traces from the connector to the header on the board that has the voltage and ground labels.
As with all electronic devices the pin labeled Vin is for positive voltage input. So if your plugging in a battery pack the positive lead goes to Vin and the negative lead goes to ground. So any battery pack that supplies between 7 and 12 v can be connected there or at the power connector.
I will do that when I am near my power meter. In the mean time, if someone that is using this one could answer, it’s appreciated.
Thank you. So, i have actually 3 ways of powering the Seeeduino V1.1. By using the Vin and GND pin, by using the power connector and by use the USB connector.
The polarity of the Seeeduino board power is printed on the trace side of the pcb. It is backwards from the usual 2 pin JST pigtails so be careful to check. The positive connector is closest to the board edge, negative is next to the switch.
