Seeeduino xiao assembly programming
Hi there,
I´m trying to replicate the blinking led programm of c in assembly, for educational purposes
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(250);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
This is the assembly code
.syntax unified
.cpu cortex-m0plus
.thumb
.global main
.equ LED_PIN, 0x50000000 // Memory-mapped address of LED pin
.equ LED_PIN_CONFIG, 0x40000000 // Memory-mapped address of the pin configuration register
.equ LED_PIN_MASK, 0x2000 // 1 shifted 13 times to the left
.equ DELAY_COUNT, 0xFFFFFF
main:
    ldr r0, =LED_PIN_CONFIG
    movs r1, #1
    str r1, [r0] // Configure LED_PIN as an output
setup:
    ldr r0, =LED_PIN
    ldr r1, =LED_PIN_MASK
turn_on:
    str r1, [r0] // Turn on the LED
    bl delay
turn_off:
    movs r1, #0
    str r1, [r0] // Turn off the LED
    bl delay
    b setup
delay:
    ldr r0, =DELAY_COUNT
delay_loop:
    subs r0, r0, #1
    bne delay_loop
    bx lr
I compiled it, and got the bin
arm-none-eabi-as -mcpu=cortex-m0plus -mthumb -o blink.o blink.S
arm-none-eabi-ld -o blink.elf blink.o
arm-none-eabi-objcopy -O binary blink.elf blink.bin
I upload the binary
It uploads with this message:
Set binary mode
readWord(addr=0)=0x20002dd8
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v1.1 [Arduino:XYZ] Nov 27 2019 16:35:59
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device       : ATSAMD21G18A
Chip ID      : 10010005
Version      : v1.1 [Arduino:XYZ] Nov 27 2019 16:35:59
Address      : 8192
Pages        : 3968
Page Size    : 64 bytes
Total Size   : 248KB
Planes       : 1
Lock Regions : 16
Locked       : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security     : false
Boot Flash   : true
readWord(addr=0x40000834)=0x7000a
BOD          : true
BOR          : true
Arduino      : FAST_CHIP_ERASE
Arduino      : FAST_MULTI_PAGE_WRITE
Arduino      : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.851 seconds
Write 52 bytes to flash (1 pages)
write(addr=0x20005000,size=0x40)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x40)
[==============================] 100% (1/1 pages)
done in 0.083 seconds
Verify 52 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x34) = b9a0
Verify successful
done in 0.064 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
But it does not work and the board goes back to bootload mode
Anyone have an idea on how to achive this?
i not see a command that looks like "jump to turn_on:"
That seems extremely unlikely. All the peripherals are in the 0x4xxxyyyy range, except for the high speed IOBUS which is at 0x60000000
SAMD doesn't seem to have anything a 0x6..., and a memory reference to non-existent memory will probably either reset or hang the chip.
Also, if the LED_PIN_MASK is 0x2000, you probably need a 0x2000 in the DIR register as well.
BTW, Even in assembly language, you ought to be using the CMSIS include files and symbolic names, so that you'd have .equ LED_PIN, REG_PORT_OUT0 or similar.
