Hey everyone!
If you have the patience to read this long message (lol), I’d really appreciate your advice.
I’m working on a multidisciplinary project with two Mechanical Engineering students, two Electrical Engineering students, and me (a Computer and Communication Engineering student). Our goal is to build a wave generator for an OWC (Oscillating Water Column) project.
My Role is to develop a web-based interface that allows users to:
Start a simulation remotely by setting the wave frequency and amplitude.
View real-time data on a chart.
Generate reports from previous simulations.
Start a simulation directly from the generator (without live visualization) while still logging data for later reports.
Planned Architecture:
Frontend: Vue.js
Backend: Laravel + database (for logging and managing data)
MQTT Broker: Handles communication between the web app, the generator, and the sensors
ESP (IoT device): Connected to the generator and a wave height sensor
Power Consumption Monitoring: Tracks the generator’s energy usage
Web App Features
The system will have two main sections:
Start Simulation: Sends frequency & amplitude to the generator and receives wave height data.
View Reports: Fetches historical data from the backend and displays it in charts.
MQTT Communication Flow:
The frontend publishes the wave frequency & amplitude.
The ESP listens to these values and controls the generator.
The ESP publishes wave height data, which the backend stores in the database.
If the simulation is started directly from the generator, it logs data without requiring the web interface.
Where I Need Advice:
Does my architecture make sense? Any improvements?
Which MQTT broker would be best? Since the university wants this project to run long-term, reliability is key. Which broker would you recommend?
Which components should I use?
ESP: I’m considering the Wemos D1 Mini (WiFi-enabled). Would this be a good choice?
Wave height sensor: It needs to be very accurate. Any recommendations?
Physical Interface for Local Control This is where I’m most lost—I need help figuring out:
How to structure what components I need to use here. The user should be able to enter the frequency and amplitude of the wave and start the generator locally.
Should I add a touchscreen, or would buttons to increase the frequency work better? Or perhaps something else?
Is one Wemos enough to manage the connection and communication with the generator, or should I add another, larger Arduino to communicate with the Wemos via TX and RX?
Do I need any additional components for the local control system?
Handling Local vs. Remote Control
If the system is running locally, should I disable remote control?
How can I properly separate local and remote operation to avoid conflicts?
I would love to hear your thoughts and suggestions! Thanks in advance! ![]()
