Seeking help with first project (Automatic ball launcher)
Hi to all , I bought a project ,was promised the code but the file was empty when I downloaded it.
(already tried contacting him and ask to supply the code ,had no luck)
I'm making a aromatic ball launcher for our very hyper border collie.
Components used:
2x brushless motors
2x esc
1xPIR sensor
1x servo motor
1x LED
the idea is when the PIR sensor detect a signal a LED turns on, the two motors needs to spin @ 100% power for 1 second then the servo motor needs to turn anti clockwise 90 degrees to release the tennis ball ,the two motors keeps spinning for a other 2 seconds before they powers down then 8 seconds delay before the PIR sensor looks for a signal again.
below is my crippled code.
#include <Servo.h>
Servo esc1;  // Create a servo object for the first ESC
Servo esc2;  // Create a servo object for the second ESC
const int servoPin = 5;   // Replace with the actual pin for the servo
Servo myservo;
  esc1.attach(9);  // Attach the first ESC to pin 9
  esc2.attach(10); // Attach the second ESC to pin 10
  esc1.writeMicroseconds(1000);  // Initialize the first ESC with 0% throttle
  esc2.writeMicroseconds(1000);  // Initialize the second ESC with 0% throttle
  pinMode(2, INPUT);//define arduino pin
  pinMode(3, OUTPUT);//define arduino pin
  Serial.begin(9600);//enable serial monitor
  delay(5000);  // Delay for 5 seconds
  myservo.attach(5);
  //servo position to 0 degrees
    myservo.write(0);
  bool value = digitalRead(2);//get value and save it boolean veriable
  if (value == 1) { //check condition
    Serial.println("ON");//print serial monitor ON
    digitalWrite(3,HIGH);//LED on
    esc1.writeMicroseconds(1900); // Start motor 1 at 90%
    esc2.writeMicroseconds(1900); // Start motor 2 at 90%
    delay(1500); // Run motors for 1.5 seconds
    myservo.write(-90); // Rotate the servo to 90 degrees
    delay(2000); // Run motors for 2 seconds
    esc1.writeMicroseconds(1000); // Stop motor 1
    esc2.writeMicroseconds(1000); // Stop motor 2
    myservo.write(0); // Reset servo position to 0 degrees
    delay(8000); // Wait for 8 seconds
    Serial.println("OFF");//print serial monitor OFF
    digitalWrite(3,LOW);//LED off
so the code does something. what does it do that you don't want?
(may be you need for the PIR to reset once triggered?)
a finite state machine code structure would be a good way to approach your needs
first issue is, when the PIR sensor is triggered, the 2 motors runs in a loop ,so yes sounds like a good idea to reset the PIR sensor ,would you perhaps know how?
second issue is, the servo motor does not stop it keeps rotating
but for some unknown reason ,it seems like its behaving like it should know.
Hi, @the_mufasa
Welcome to the forum.
Can you please post a link to where you purchased the kit?
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
also sometimes the servo motor does not reset and stays open (on 90 degrees)
Hi Tom
Here you go
HI,
A schematic would be good?
Link to ESC and motors?
How are you powering your project?
What model Arduino are you using?
Can you please tell us your electronics, programming, arduino, hardware experience?
Do you have a DMM?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
here is an example with a state machine
launch the simulation using the green arrow in the simulation window
(some wires are hidden for clarity)
to trigger a PIR detection in wokwi you click on the PIR sensor object and at the top of the simulation window you have a button to simulate motion
You'll see the servos moving towards various positions based on the timing you defined in your first post and after the pause the system is ready again. (the serial monitor shows some status info too)
of course you need the motors to be correctly powered, not through your Arduino !!
click to see the code
// https://forum.arduino.cc/t/seeking-help-with-first-project-automatic-ball-launcher/1171365/1
    - a LED turns on
    - the two motors needs to spin @ 100% power for 1 second
    - then the servo motor needs to turn anti clockwise 90 degrees to release the tennis ball
    - the two motors keeps spinning for a other 2 seconds before they powers down
    - then 8 seconds delay before the PIR sensor looks for a signal again
enum {IDLE, ACTIVATION, RELEASE, POST_RELEASE, WAITING } state = IDLE;
const unsigned long activationDuration  = 1000; // 1s
const unsigned long releaseDuration = 2000; // 2s
const unsigned long minWaitPostTrigger  = 8000; // 8s
const int lockBallAngle = 45;
const int releaseBalldAngle = 135;
unsigned long startTime;
#include <Servo.h>
const byte pirPin = 2;
const byte ledPin = 3;
const byte servoPin = 5;
const byte esc1Pin = 9;
const byte esc2Pin = 10;
Servo esc1, esc2, servo;
void stopMotors() {
  esc1.writeMicroseconds(1000);  // 0% throttle
  esc2.writeMicroseconds(1000);  // 0% throttle
void activateMotors() {
  esc1.writeMicroseconds(1900);  // 90% throttle
  esc2.writeMicroseconds(1900);  // 90% throttle
void lockBall() {
  servo.write(lockBallAngle);
void releaseBall() {
  servo.write(releaseBalldAngle);
void ledOn() {
  digitalWrite(ledPin, HIGH);
void ledOff() {
  digitalWrite(ledPin, LOW);
bool motionDetected() {
  return digitalRead(pirPin) == HIGH;
  stopMotors();
  lockBall();
  pinMode(ledPin, OUTPUT);
  pinMode(pirPin, INPUT);
  esc1.attach(esc1Pin);
  esc2.attach(esc2Pin);
  servo.attach(servoPin);
  switch (state) {
    case IDLE:
      if (motionDetected()) {
        Serial.println(F("MOVEMENT DETECTED"));
        Serial.println(F("SYSTEM ACTIVATION"));
        ledOn();
        activateMotors();
        startTime = millis();
        state = ACTIVATION;
    case ACTIVATION:
      if (millis() - startTime >= activationDuration) {
        Serial.println(F("BALL RELEASED"));
        releaseBall();
        state = RELEASE;
    case RELEASE:
      if (millis() - startTime >= releaseDuration) {
        Serial.println(F("POST RELEASE PHASE ENDED. SYSTEM DEACTIVATION"));
        stopMotors();
        lockBall();
        state = POST_RELEASE;
    case POST_RELEASE:
      if (millis() - startTime >= minWaitPostTrigger) {
        Serial.println(F("PAUSE ENDED, WAITING FOR PIR TO BECOME IDLE."));
        state = WAITING;
    case WAITING:
      if (not motionDetected()) {
        Serial.println(F("PIR IS IDLE, READY AGAIN."));
        ledOff();
        state = IDLE;
Hi J-M-L
my apologies for not being active on the forum and thanking you for your help with the coding
its been a few months since i had time for hobby projects
your coding helped a lot , got it working but it turns our the pir sensor was to sensitive.
after replacing it with a adjustable one even on the lowest setting it was still picking up movement from to far.
So I've decided to use a infrared send and reviver, it looks promising I just need to adjust the code to work with that sensor now.
