self avoidance autonomous robot with "homing" function
Hi im not very good at programming, basically my project is to do a self avoidance robot w self charging.
Ignoring the self charging part, i am trying to make my robot to go back to "home" once it travels for either x amount of time, or by travelling x distance just to show that it works.
Currently, i am only at the level of making my robot move by 30cm, then reverse back to home in a straight line.
My question is, i am trying to make it to move around while avoiding objects, and then return back to home. Is it doable with my method?
Code as below.
#include "TimerOne.h"
#include <AFMotor.h>      //add Adafruit Motor Shield library
#include <NewPing.h>      //add Ultrasonic sensor library
#include <HCSR04.h>
// Initialize sensor that uses digital pins 13 and 12 for Ultrasonic sensor
int triggerPin = 12;
int echoPin = 13;
UltraSonicDistanceSensor distanceSensor(triggerPin, echoPin);
//For light encoder for motor
const int Left_IN_A0 = A0; // analog input
const int Left_IN_D2 = 2; // digital input
const byte MOTOR1 = 2;  // Motor 1 Interrupt Pin - INT 0
//const byte MOTOR2 = 3;  // Motor 2 Interrupt Pin - INT 1
AF_DCMotor leftMotor (2, MOTOR12_1KHZ); //M2 in
AF_DCMotor rightMotor (4, MOTOR12_1KHZ);
// Integers for pulse counters
unsigned int counter1 = 0;
unsigned int counter2 = 0;
// Float for number of slots in encoder disk
float diskslots = 20;  // Change to match value of encoder disk
void ISR_count1()
  counter1++;  // increment Motor 1 counter value
void ISR_count2()
  counter2++;  // increment Motor 1 counter value
/*void ISR_timerone()
  Timer1.detachInterrupt();  // Stop the timer
  Serial.print("Motor Speed 1: ");
  float rotation1 = (counter1 / diskslots);  // calculate RPS for Motor 1
  float distance = (rotation1); //circmference of wheel x rotation
  Serial.print(distance);
  Serial.println(" cm - ");
  //counter1 = 0;  //  reset counter to zero
  Timer1.attachInterrupt( ISR_timerone );  // Enable the timer
  Timer1.initialize(500000); // set timer for 1sec
  attachInterrupt(digitalPinToInterrupt (MOTOR1), ISR_count1, RISING);  // Increase counter 1 when speed sensor pin goes High
 // Timer1.attachInterrupt( ISR_timerone ); // Enable the timer
  leftMotor.setSpeed(210);
  leftMotor.run(RELEASE);
  rightMotor.setSpeed(205);
  rightMotor.run(RELEASE);
  float distance1 = (rotation1); //circmference of wheel x rotation
  Serial.print(distance1);
  Serial.print(" cm - ");
 if (distance1 <= 30.00)
  moveForward();
 goBackToHome();
void goBackToHome(){
  attachInterrupt(digitalPinToInterrupt (MOTOR1), ISR_count2, RISING);
  float rotation2 = (counter2 / diskslots);  // calculate RPS for Motor 1
  float distance2 = (rotation2); //circmference of wheel x rotation
   Serial.print(distance2);
  moveBackward();
  if ( distance2 >= 30){
  motorStop();
void turnRight() {
  //motorSet = "RIGHT";
  leftMotor.run(FORWARD);      // turn left motor forward
  rightMotor.run(BACKWARD);    // turn right motor backward
  delay(1200); // run motors this way for 1000
  //motorSet = "FORWARD";
  rightMotor.run(FORWARD);
void moveForward() {
    leftMotor.run(FORWARD);      // turn it on going forward
    rightMotor.run(FORWARD);     // turn it on going forward
void moveBackward() {
    leftMotor.run(BACKWARD);      // turn it on going forward
    rightMotor.run(BACKWARD);     // turn it on going forward
void motorStop() {
schematic diagram (POSTER + REPORT).pdf (75.4 KB)
Can be sure that both wheels are the same diameter, both motors rotate at the same rate and that the wheels will never slip on the surface during starting, turning and stopping. How are you ensuring that the robot travels in a straight line in your current code ?
UKHeliBob:
Hi, thank you for your quick reply.
i am not sure if it can, but the idea is to rely on the motor encoder that is detecting the encoder disks turn.
The disk has 20slots, so 20 "RISING" pin = 1 revolution. My distance does not have to be exact, but at least try to make it near "home"
i would like to know the idea of how to code it to do it that way/ if its possible.
The most general approach is to have the robot know where it is located on a XY grid, as well as the location of home on that grid. That is much harder than it sounds, so work on solving that problem first.
Once you know where you are it is easy to navigate to somewhere else.
Some other things to think about. If the robot has avoided obstacles before returning home then should it try to go directly home or should it retrace its steps including the steps involved in avoiding obstacles ?
Does your current code and hardware perform adequately over a straight 30cm there and back run ? Try moving 30cm forward, stopping, turning 90 anticlockwise, 180 degrees clockwise, 90 degrees anticlockwise then reversing for 30cm. Did the robot make it home, or close enough ?
How are you going to measure the rotation angles ? Your only method with the current hardware is to measure wheel rotation, hence the importance of wheel slip. You will also need a method of keeping the robot moving in a straight line by comparing wheel rotations and applying corrections to keep them rotating at the same rate with, adjustment for any difference in wheel circumference
I am sorry if I am making this sound difficult, but it is
