Self balancing robot help
Hello! I am trying to build a self balancing robot and it is working really bad and has some very strange bugs. Firstly here are the components i am using:
  • arduino uno
  • MPU6050 accelerometer and gyro
  • 2 steppers 17HS4401 (1.7 A, 40 N⋅cm)
  • 2 stepper drivers A4988
    And here is the code:
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
#include "math.h"
#include <AccelStepper.h>
#include <MultiStepper.h>
#include <avr/wdt.h>
#define leftMotorPWMPin   9
#define leftMotorDirPin   8
#define rightMotorPWMPin  11
#define rightMotorDirPin  10
#define Kp  10
#define Kd  0.1
#define Ki  0
#define sampleTime  0.005
#define targetAngle -2.5
MPU6050 mpu;
// Initialize AccelStepper for two motors
AccelStepper stepper1(AccelStepper::DRIVER, leftMotorPWMPin, leftMotorDirPin);
AccelStepper stepper2(AccelStepper::DRIVER, rightMotorPWMPin, rightMotorDirPin);
int16_t accY, accZ, accX, gyroX;
volatile int motorPower, gyroRate;
volatile float accAngle, gyroAngle, currentAngle, prevAngle=0, error, prevError=0, errorSum=0;
volatile byte count=0;
int distanceCm;
void init_PID() {
// Stop the timer
  TCCR1B = 0;
  // Set the timer to CTC mode
  TCCR1A = 0;  // Ensure WGM10 and WGM11 are both 0
  TCCR1B |= (1 << WGM12);  // Set WGM12 to 1
  TCCR1B &= ~(1 << WGM13); // Ensure WGM13 is 0
  // Set the compare match register to 1249
  OCR1A = 1249;
  // Set the prescaler to 64 and start the timer
  TCCR1B |= (1 << CS11) | (1 << CS10);  // CS11 = 1 and CS10 = 1
  // Enable Timer Compare Interrupt
  TIMSK1 |= (1 << OCIE1A);  // Set the OCIE1A bit high to enable the interrupt
  // Ensure global interrupts are enabled
  sei();
  // set the motor control and PWM pins to output mode
  pinMode(leftMotorPWMPin, OUTPUT);
  pinMode(leftMotorDirPin, OUTPUT);
  pinMode(rightMotorPWMPin, OUTPUT);
  pinMode(rightMotorDirPin, OUTPUT);
  // initialize the MPU6050 and set offset values
  mpu.initialize();
  mpu.setXAccelOffset(594);
  mpu.setYAccelOffset(3774);
  mpu.setZAccelOffset(1398);
  mpu.setXGyroOffset(148);
  mpu.setYGyroOffset(86);
  mpu.setZGyroOffset(6);
  stepper1.setMaxSpeed(1000);
  stepper1.setAcceleration(500);
  stepper2.setMaxSpeed(1000);
  stepper2.setAcceleration(500);
   wdt_enable(WDTO_2S);
  // initialize PID sampling loop
  init_PID();
volatile bool updateFlag = false; // Flag to signal when to update PID calculations
ISR(TIMER1_COMPA_vect) {
    updateFlag = true; // Set the flag to true to indicate data should be processed
    wdt_reset();
    if (updateFlag) {
        // Reset the flag
        updateFlag = false;
        // Perform sensor reading and calculations
        readSensors();
        calculatePID();
        // Update motors
        stepper1.setSpeed(-motorPower);
        stepper2.setSpeed(motorPower);
        // Serial.println(motorPower);
    stepper1.runSpeed();
    stepper2.runSpeed();
void readSensors() {
    accY = mpu.getAccelerationY();
    accZ = mpu.getAccelerationZ();
    accX = mpu.getAccelerationX();
    gyroX = mpu.getRotationX();
    accAngle = atan2(accX, accZ) * RAD_TO_DEG;
    gyroRate = map(gyroX, -32768, 32767, -250, 250);
    gyroAngle = (float)gyroRate * sampleTime;
void calculatePID() {
    currentAngle = 0.9934 * (prevAngle + gyroAngle) + 0.0066 * (accAngle);
    error = currentAngle - targetAngle;
    errorSum += error;
    errorSum = constrain(errorSum, -300, 300);
    motorPower = Kp * error + Ki * errorSum * sampleTime - Kd * (currentAngle - prevAngle) / sampleTime;
    motorPower = constrain(motorPower, -500, 500);
    prevAngle = currentAngle;
I am sampling from the mpu6050 and modifying the motor power with an interrupt at 5ms on timer1.
A strange bug that happens here is that the program will just stop working at random times. It will not even print anything to the serial. I read that it might be from the timer i am using maybe it conflicts with something else? To temporarily solve that i set up a watchdog that resets the arduino but i want get rid of this bug if i can.
Now for the balancing, The robot actually oscillates well in the balanced position and it can stay like that but at any push that is not a very light touch it will not be able to recover. Do you have any advice on how to tune the pid constants to achieve a better recovery?.
Another thing that is bothering me is that the steppers, while they are working they seem to have a very forced movement like they are struggling to make every step and they are not smooth at all. Any idea why that might happen?
Thank you for your time and I appreciate any ideas since I am really lost!
What are the details of the power supply? Also, include a wiring diagram of your project.
Test lowering the Kd by a few percent.
Sure! Sorry, I am new and i didn't know what would be needed. For the power supply I am using a LiPo Gens Ace, 11.1V, 700mAh. I also have a bluetooth hc-05 module, a PIR sensor and a buzzer in this project. The bluetooth module is for remote control after i make it balance and the buzzer should be activate when the sensor detects movement but i thought that these are not relevant right now. Here is the wiring:
Let me know if there is something unclear or if any other details are needed.
Ok so i did this and it seems to balance pretty well when the program actually works but i think the actual problem is that it just stops running at random moments and if that happens during a fall it will not work. I tried switching to timer2 and it does the same thing and when the wd resets it it's too late.
In case i needed to reply to this, I posted the wiring and the details about the power supply
That was my intention. Do some more testing, lowering more until the result is not better. May then try higiher values, in small steps, and look for the same. Get the center, the best value.
I don't comment on that as I don't know the timers, how they work and what libraries that might use the same timer.
Good. About the drivers, do they have heat sinks, do they get warm? 1.7 Amp sounds like too much to me. I run those drivers at 1.5 Amp, use heat sinks and fan cooling.
What about the batteries? What currents are they specified for? You might be drawing too much current.
A bit of a guess here:
If a driver is overloaded it will cut off and then the algorithms for the 6050 might collaps as there's not sensibel movements.
Oh you are right i did not place the heat sinks (oops) because i actually didn't know what they are and there was nothing specified about them in the driver's instructions. Would that be enough or do I need some additional cooling? In the driver's characteristics it's specified that they work up to 2Amp. For the battery it only says that it can provide up to 21Amp.
Where is your power supply?
In the schematic it would be the battery on the left for the steppers. If you are asking about the 5V on the arduino I don't have that right now i am powering it at the computer when testing.
(sorry... I missed that)
This can be due to insufficient power. What is the max current drawn by each motor? I imagine both motors will be near max half the time as it tries to stabilize.
Run a motor sketch moving the frame at full speed as if it was balancing to see if the "motors only" stops working. Make a sketch that requires input (grounding a pin) so if/when a brown-out occurs, the sketch stops (waiting for the input to continue).
