Self balancing robot - Randomly freezes
My code is shown below:
#include <Wire.h>                                            //Include the Wire.h library so we can communicate with the gyro
int gyro_address = 0x68;                                     //MPU-6050 I2C address (0x68 or 0x69)
int acc_calibration_value = 1000;                            //Enter the accelerometer calibration value
volatile long StartTime = 0;
volatile long CurrentTime = 0;
volatile long Pulses = 0;
int PulseWidth = 0;
volatile long StartTime2 = 0;
volatile long CurrentTime2 = 0;
volatile long Pulses2 = 0;
int PulseWidth2 = 0;
//Various settings
float pid_p_gain = 18;                                       //Gain setting for the P-controller (15)
float pid_i_gain = 0;                                      //Gain setting for the I-controller (1.5)
float pid_d_gain = 10;                                       //Gain setting for the D-controller (30)
float turning_speed = 90;                                    //Turning speed (20)
float max_target_speed = 100;                                //Max target speed (100)
//Declaring global variables
byte start, received_byte, low_bat;
int left_motor, throttle_left_motor, throttle_counter_left_motor, throttle_left_motor_memory;
int right_motor, throttle_right_motor, throttle_counter_right_motor, throttle_right_motor_memory;
int battery_voltage;
int receive_counter;
int gyro_pitch_data_raw, gyro_yaw_data_raw, accelerometer_data_raw;
long gyro_yaw_calibration_value, gyro_pitch_calibration_value;
unsigned long loop_timer;
float angle_gyro, angle_acc, angle, self_balance_pid_setpoint;
float pid_error_temp, pid_i_mem, pid_setpoint, gyro_input, pid_output, pid_last_d_error;
float pid_output_left, pid_output_right;
//Setup basic functions
void setup(){
  Serial.begin(115200);                                                       //Start the serial port at 9600 kbps
  Wire.begin();
                                                           //Start the I2C bus as master
  TWBR = 12;        //Set the I2C clock speed to 400kHz
  //To create a variable pulse for controlling the stepper motors a timer is created that will execute a piece of code (subroutine) every 20us
  //This subroutine is called TIMER2_COMPA_vect
  TCCR2A = 0;                                                               //Make sure that the TCCR2A register is set to zero
  TCCR2B = 0;                                                               //Make sure that the TCCR2A register is set to zero
  TIMSK2 |= (1 << OCIE2A);                                                  //Set the interupt enable bit OCIE2A in the TIMSK2 register
  TCCR2B |= (1 << CS21);                                                    //Set the CS21 bit in the TCCRB register to set the prescaler to 8
  OCR2A = 39;                                                               //The compare register is set to 39 => 20us / (1s / (16.000.000MHz / 8)) - 1
  TCCR2A |= (1 << WGM21);                                                   //Set counter 2 to CTC (clear timer on compare) mode
  PCICR |= B00000011;			//Bit2 = 1 -> "PCIE2" enabeled (PCINT16 to PCINT23)
  PCMSK1 |= B00000001;			//D4 and D5 will trigger interrupt
  PCMSK0 |= B00001000;			//D4 and D5 will trigger interrupt
  //By default the MPU-6050 sleeps. So we have to wake it up.
  Wire.beginTransmission(gyro_address);                                     //Start communication with the address found during search.
  Wire.write(0x6B);                                                         //We want to write to the PWR_MGMT_1 register (6B hex)
  Wire.write(0x00);                                                         //Set the register bits as 00000000 to activate the gyro
  Wire.endTransmission();                                                   //End the transmission with the gyro.
  //Set the full scale of the gyro to +/- 250 degrees per second
  Wire.write(0x1B);                                                         //We want to write to the GYRO_CONFIG register (1B hex)
  Wire.write(0x00);                                                         //Set the register bits as 00000000 (250dps full scale)
  //Set the full scale of the accelerometer to +/- 4g.
  Wire.write(0x1C);                                                         //We want to write to the ACCEL_CONFIG register (1A hex)
  Wire.write(0x08);                                                         //Set the register bits as 00001000 (+/- 4g full scale range)
  //Set some filtering to improve the raw data.
  Wire.write(0x1A);                                                         //We want to write to the CONFIG register (1A hex)
  Wire.write(0x03);                                                         //Set the register bits as 00000011 (Set Digital Low Pass Filter to ~43Hz)
  pinMode(5, OUTPUT);                                                       //Configure digital poort 2 as output
  pinMode(6, OUTPUT);                                                       //Configure digital poort 3 as output
  pinMode(7, OUTPUT);                                                       //Configure digital poort 4 as output
  pinMode(8, OUTPUT);                                                       //Configure digital poort 5 as output
  pinMode(13, OUTPUT);                                                      //Configure digital poort 6 as output
  for(receive_counter = 0; receive_counter < 500; receive_counter++){       //Create 500 loops
    if(receive_counter % 15 == 0)digitalWrite(13, !digitalRead(13));        //Change the state of the LED every 15 loops to make the LED blink fast
    Wire.beginTransmission(gyro_address);                                   //Start communication with the gyro
    Wire.write(0x43);                                                       //Start reading the Who_am_I register 75h
    Wire.requestFrom(gyro_address, 4);                                      //Request 2 bytes from the gyro
    gyro_yaw_calibration_value += Wire.read()<<8|Wire.read();               //Combine the two bytes to make one integer
    gyro_pitch_calibration_value += Wire.read()<<8|Wire.read();             //Combine the two bytes to make one integer
    delayMicroseconds(3700);                                                //Wait for 3700 microseconds to simulate the main program loop time
  gyro_pitch_calibration_value /= 500;                                      //Divide the total value by 500 to get the avarage gyro offset
  gyro_yaw_calibration_value /= 500;                                        //Divide the total value by 500 to get the avarage gyro offset
  loop_timer = micros() + 4000;                                             //Set the loop_timer variable at the next end loop time
//Main program loop
double vX, vY;
void loop(){
  if (Pulses < 2200){
    PulseWidth = Pulses;
  if (Pulses2 < 2200){
    PulseWidth2 = Pulses2;
  vX = map(PulseWidth,1000,2000,-1000,1000);
  vY = map(PulseWidth2,1000,2000,-1000,1000);
  vX = vX / 1000;
  vY = vY / 1000;
  Serial.println(vY);
  //Angle calculations
  Wire.write(0x3F);                                                         //Start reading at register 3F
  Wire.requestFrom(gyro_address, 2);                                        //Request 2 bytes from the gyro
  accelerometer_data_raw = Wire.read()<<8|Wire.read();                      //Combine the two bytes to make one integer
  accelerometer_data_raw += acc_calibration_value;                          //Add the accelerometer calibration value
  if(accelerometer_data_raw > 8200)accelerometer_data_raw = 8200;           //Prevent division by zero by limiting the acc data to +/-8200;
  if(accelerometer_data_raw < -8200)accelerometer_data_raw = -8200;         //Prevent division by zero by limiting the acc data to +/-8200;
  angle_acc = asin((float)accelerometer_data_raw/8200.0)* 57.296;           //Calculate the current angle according to the accelerometer
  if(start == 0 && angle_acc > -0.5&& angle_acc < 0.5){                     //If the accelerometer angle is almost 0
    angle_gyro = angle_acc;                                                 //Load the accelerometer angle in the angle_gyro variable
    start = 1;                                                              //Set the start variable to start the PID controller
  Wire.write(0x43);                                                         //Start reading at register 43
  Wire.requestFrom(gyro_address, 4);                                        //Request 4 bytes from the gyro
  gyro_yaw_data_raw = Wire.read()<<8|Wire.read();                           //Combine the two bytes to make one integer
  gyro_pitch_data_raw = Wire.read()<<8|Wire.read();                         //Combine the two bytes to make one integer
  gyro_pitch_data_raw -= gyro_pitch_calibration_value;                      //Add the gyro calibration value
  angle_gyro += gyro_pitch_data_raw * 0.000031;                             //Calculate the traveled during this loop angle and add this to the angle_gyro variable
  //MPU-6050 offset compensation
  //Not every gyro is mounted 100% level with the axis of the robot. This can be cause by misalignments during manufacturing of the breakout board.
  //As a result the robot will not rotate at the exact same spot and start to make larger and larger circles.
  //To compensate for this behavior a VERY SMALL angle compensation is needed when the robot is rotating.
  //Try 0.0000003 or -0.0000003 first to see if there is any improvement.
  gyro_yaw_data_raw -= gyro_yaw_calibration_value;                          //Add the gyro calibration value
  //Uncomment the following line to make the compensation active
  //angle_gyro -= gyro_yaw_data_raw * 0.0000003;                            //Compensate the gyro offset when the robot is rotating
  angle_gyro = angle_gyro * 0.9996 + angle_acc * 0.0004;                    //Correct the drift of the gyro angle with the accelerometer angle
  //PID controller calculations
  //The balancing robot is angle driven. First the difference between the desired angel (setpoint) and actual angle (process value)
  //is calculated. The self_balance_pid_setpoint variable is automatically changed to make sure that the robot stays balanced all the time.
  //The (pid_setpoint - pid_output * 0.015) part functions as a brake function.
  pid_error_temp = angle_gyro - 10 - self_balance_pid_setpoint - pid_setpoint;
  if(pid_output > 10 || pid_output < -10)pid_error_temp += pid_output * 0.015 ;
  pid_i_mem += pid_i_gain * pid_error_temp;                                 //Calculate the I-controller value and add it to the pid_i_mem variable
  if(pid_i_mem > 400)pid_i_mem = 400;                                       //Limit the I-controller to the maximum controller output
  else if(pid_i_mem < -400)pid_i_mem = -400;
  //Calculate the PID output value
  pid_output = pid_p_gain * pid_error_temp + pid_i_mem + pid_d_gain * (pid_error_temp - pid_last_d_error);
  if(pid_output > 400)pid_output = 400;                                     //Limit the PI-controller to the maximum controller output
  else if(pid_output < -400)pid_output = -400;
  pid_last_d_error = pid_error_temp;                                        //Store the error for the next loop
  if(pid_output < 5 && pid_output > -5)pid_output = 0;                      //Create a dead-band to stop the motors when the robot is balanced
  if(angle_gyro > 30 || angle_gyro < -30 || start == 0 || low_bat == 1){    //If the robot tips over or the start variable is zero or the battery is empty
    pid_output = 0;                                                         //Set the PID controller output to 0 so the motors stop moving
    pid_i_mem = 0;                                                          //Reset the I-controller memory
    start = 0;                                                              //Set the start variable to 0
    self_balance_pid_setpoint = 0;                                          //Reset the self_balance_pid_setpoint variable
  //Control calculations
  pid_output_left = pid_output;                                             //Copy the controller output to the pid_output_left variable for the left motor
  pid_output_right = pid_output;                                            //Copy the controller output to the pid_output_right variable for the right motor
  pid_output_left += 0.25*(0)*turning_speed;
  pid_output_right -= 0.25*(0)*turning_speed;
  if(pid_setpoint > -2.5)pid_setpoint += 0.05;
  pid_setpoint += 0.005*vX;
  if(pid_setpoint < 2.5)pid_setpoint -= 0.05;
  if(pid_setpoint > 0.5)pid_setpoint -=0.05;                              //If the PID setpoint is larger then 0.5 reduce the setpoint with 0.05 every loop
  else if(pid_setpoint < -0.5)pid_setpoint +=0.05;                        //If the PID setpoint is smaller then -0.5 increase the setpoint with 0.05 every loop
  else pid_setpoint = 0;                                                  //If the PID setpoint is smaller then 0.5 or larger then -0.5 set the setpoint to 0
  //The self balancing point is adjusted when there is not forward or backwards movement from the transmitter. This way the robot will always find it's balancing point
  if(pid_setpoint == 0){                                                    //If the setpoint is zero degrees
    if(pid_output < 0)self_balance_pid_setpoint += 0.0015;                  //Increase the self_balance_pid_setpoint if the robot is still moving forewards
    if(pid_output > 0)self_balance_pid_setpoint -= 0.0015;                  //Decrease the self_balance_pid_setpoint if the robot is still moving backwards
  //Motor pulse calculations
  //To compensate for the non-linear behaviour of the stepper motors the folowing calculations are needed to get a linear speed behaviour.
  if(pid_output_left > 0)pid_output_left = 405 - (1/(pid_output_left + 9)) * 5500;
  else if(pid_output_left < 0)pid_output_left = -405 - (1/(pid_output_left - 9)) * 5500;
  if(pid_output_right > 0)pid_output_right = 405 - (1/(pid_output_right + 9)) * 5500;
  else if(pid_output_right < 0)pid_output_right = -405 - (1/(pid_output_right - 9)) * 5500;
  //Calculate the needed pulse time for the left and right stepper motor controllers
  if(pid_output_left > 0)left_motor = 400 - pid_output_left;
  else if(pid_output_left < 0)left_motor = -400 - pid_output_left;
  else left_motor = 0;
  if(pid_output_right > 0)right_motor = 400 - pid_output_right;
  else if(pid_output_right < 0)right_motor = -400 - pid_output_right;
  else right_motor = 0;
  //Copy the pulse time to the throttle variables so the interrupt subroutine can use them
  throttle_left_motor = left_motor;
  throttle_right_motor = right_motor;
  //Loop time timer
  //The angle calculations are tuned for a loop time of 4 milliseconds. To make sure every loop is exactly 4 milliseconds a wait loop
  //is created by setting the loop_timer variable to +4000 microseconds every loop.
  while(loop_timer > micros());
  loop_timer += 4000;
//Interrupt routine  TIMER2_COMPA_vect
ISR(TIMER2_COMPA_vect){
  //Left motor pulse calculations
  throttle_counter_left_motor ++;                                           //Increase the throttle_counter_left_motor variable by 1 every time this routine is executed
  if(throttle_counter_left_motor > throttle_left_motor_memory){             //If the number of loops is larger then the throttle_left_motor_memory variable
    throttle_counter_left_motor = 0;                                        //Reset the throttle_counter_left_motor variable
    throttle_left_motor_memory = throttle_left_motor;                       //Load the next throttle_left_motor variable
    if(throttle_left_motor_memory < 0){                                     //If the throttle_left_motor_memory is negative
      digitalWrite(8,LOW);                                                  //Set output 3 low to reverse the direction of the stepper controller
      throttle_left_motor_memory *= -1;                                     //Invert the throttle_left_motor_memory variable
    else {digitalWrite(8,HIGH);}                                               //Set output 3 high for a forward direction of the stepper motor
  else if(throttle_counter_left_motor == 1) {digitalWrite(6,HIGH);}             //Set output 2 high to create a pulse for the stepper controller
  else if(throttle_counter_left_motor == 2) {digitalWrite(6, LOW);}             //Set output 2 low because the pulse only has to last for 20us
  //right motor pulse calculations
  throttle_counter_right_motor ++;                                          //Increase the throttle_counter_right_motor variable by 1 every time the routine is executed
  if(throttle_counter_right_motor > throttle_right_motor_memory){           //If the number of loops is larger then the throttle_right_motor_memory variable
    throttle_counter_right_motor = 0;                                       //Reset the throttle_counter_right_motor variable
    throttle_right_motor_memory = throttle_right_motor;                     //Load the next throttle_right_motor variable
    if(throttle_right_motor_memory < 0){                                    //If the throttle_right_motor_memory is negative
      digitalWrite(7,LOW);                                                  //Set output 5 low to reverse the direction of the stepper controller
      throttle_right_motor_memory *= -1;                                    //Invert the throttle_right_motor_memory variable
    else digitalWrite(7,HIGH);                                               //Set output 5 high for a forward direction of the stepper motor
  else if(throttle_counter_right_motor == 1){digitalWrite(5,HIGH);}            //Set output 4 high to create a pulse for the stepper controller
  else if(throttle_counter_right_motor == 2){digitalWrite(5,LOW);}            //Set output 4 low because the pulse only has to last for 20us
ISR (PCINT0_vect)
   CurrentTime = micros();
  if (CurrentTime > StartTime){
    Pulses = CurrentTime - StartTime;
    StartTime = CurrentTime;
ISR (PCINT1_vect)
   CurrentTime2 = micros();
  if (CurrentTime2 > StartTime2){
    Pulses2 = CurrentTime2 - StartTime2;
    StartTime2 = CurrentTime2;
The robot works perfectly... For about 30 seconds. Then the motors begin rotating in a particular direction on their own and it stops responding. Serial monitor shows the printing of values stopped, so something causes the code to hang.
Please do not start new threads on the same topic. Continue the discussion here.
Would this fix that bug?
while(micros() - loop_timer < 4000);
  loop_timer = micros();
Could my problem be related to the fact that interrupts may be called at the same time and interfere with each other?
Before I implemented the controller code, it worked fine, able to stand on its own for several minutes. Now it doesn't work, even if I remove the controller code.
You need to prevent interrupts at the moment that you use variables in main code that are set from interrupts.
noInterrupts();
\\\do something with variables set from interrupt
interrupts();
And your ISR's are pretty long. Try to set a flag only in your ISR and move all code into main...
What part of the code do you consider the controller code?
Anything involving the data from the RC reciever, or the variables vX and vY
Also it's not strictly 30s, its just roughly that. Sometimes it freezes after a few seconds of balancing, sometimes after a few minutes. Whatever it is, the motor interrupts are still being called so the Arduino hasnt hung up completely.
My code now:
volatile unsigned long StartTime = 0;
volatile unsigned long CurrentTime = 0;
volatile unsigned long Pulses = 0;
int PulseWidth = 0;
volatile unsigned long StartTime2 = 0;
volatile unsigned long CurrentTime2 = 0;
volatile unsigned long Pulses2 = 0;
//Various settings
void setup(){
  Wire.begin();
//Main program loop
int vX, vY;
void loop(){
  if (Pulses < 2200){
    noInterrupts();
    interrupts();
    noInterrupts();
    interrupts();
  vX = 0;
  vY = 0;
  //Loop time timer
ISR (PCINT0_vect)
ISR (PCINT1_vect)
The same issue happened, even with this. I'm starting to wonder if this is a hardware problem?
I Implemented this. It didn't help the issue.
Here you also use Pulses
if (Pulses < 2200){
So this should also be protected...
Would the proper syntax be
noInterrupts();
if (Pulses < 2200){
interrupts();
You did not share much about your hardware. So we cannot judge...
Yep!
Arduino Nano to control it
Two A4988 drivers with NEMA 17 steppers
16V LiPo battery
FS-IA6 RX
An obscene amount of wires
LM2596 to drop the voltage to one the Arduino prefers
MPU6050
How do you know the interrupts are still working?
The motor continues to rotate, and my driver is one of the ones where you need a pulse to the step pin to move the motors
Can you add a blinking led from main? That would show if loop is still running...
Is the loop() still running?
