So I have two XBee®-PRO 900HP/XSC RF Modules connected to two different arduinos and I am trying to send a value from a temperature sensor which is connected to one of the arduinos to the other.The problem is that the value that is received is not a decimal number but rather an integer
even though it is sent as a float.Here's what my serial monitor shows;
coordinator or sender;
and here is what the receiver receives;
Is it a problem with the code you didn't post?
It seems human communication has regressed - resorting to posting pictures, instead of text.
I despair.
Should I post a picture of a book?
Instead of trying to be funny can you at least give me an idea of what to do?
Funny?
You think it's funny?
Post code, not pictures - I can't compile code in Photoshop.
Why is this so hard to comprehend?
ok coordinator's code
#include<SoftwareSerial.h>
#include <XBee.h>
XBee xbee = XBee();
SoftwareSerial XBee(2,3);
const int SENSOR_PIN = 5; // Arduino pin connected to DS18B20 sensor's DQ pin
OneWire oneWire(SENSOR_PIN); // setup a oneWire instance
DallasTemperature tempSensor(&oneWire); // pass oneWire to DallasTemperature library
float tempCelsius; // temperature in Celsius
float tempFahrenheit; // temperature in Fahrenheit
Serial.begin(9600); // initialize serial
XBee.begin(9600);
tempSensor.begin(); // initialize the sensor
float temp;
tempSensor.requestTemperatures(); // send the command to get temperatures
tempCelsius = tempSensor.getTempCByIndex(0); // read temperature in Celsius
temp= tempCelsius ;
XBee.write(temp);
Serial.print("Temperature: ");
Serial.print(temp); // print the temperature in Celsius
Serial.println("°C");
and what the serial monitor displays;
Temperature: 23.31°C
Receiver's code
#include <XBee.h>
XBee xbee = XBee();
SoftwareSerial XBee(3,2);
float data;
XBee.begin(9600);
if (XBee.available())
{ // If data comes in from XBee, send it out to serial monitor
//XBee.flush();
data = XBee.read();
Serial.println(data);
and serial monitor
23.00
23.00
23.00
23.00
23.00
23.00
23.00
23.00
Is that a bit better?
Write transmits a byte. The compiler converted your float for you which left you with 23.
The receiver got 23 in a single byte and converted it to a float, hence 23.00 when printed.
Much better.
I'm going to guess it is because the XBee read function returns an integer type.
Which XBee library did you install?
is there any way to use a command that can transmit a float value?
Yes, send the four bytes that make up the float, and reassemble them at the receiver.
Which XBee library are you using?
A library by FFTechBrasil
Link?
Instead of this
XBee.write(temp);
Try this:
XBee.print(temp);
Then, you will need to read the data in correctly on the other end. To prepare for that adventure, it would be a good idea to study the Serial Input Basics tutorial on the forum.
I have already tried it but the serial monitor displays completely different numbers.That's what I mean
50.00
55.00
46.00
48.00
48.00
45.00
49.00
50.00
55.00
46.00
48.00
48.00
Tried what? Post the code, using code tags.
XBee.print(temp);
instead of
XBee.write(temp);
#include <XBee.h>
XBee xbee = XBee();
float data;
XBee.begin(9600);
//XBee.flush();
data = XBee.print(); /*This line of code that you suggested
to change but as i said the serial monitor displays those
complete different numbers I sent earlier*/
