Hello,
I need to send data as fast as possible from an Arduino DUE to an extern DAC. To do so I use DMA & SPI and I want DMA to fetch data from the memory and send it to the SPI which will just relay it via its Master Output Slave input.
So far I did a DMA transfer from a variable to another, woked perfectly. I'm using the same code but change the address as SPI_TDR (Transmit Data Register), unfortunatly it's not working. I guess the address is not good but if so what should I do ?
Here is my code :
#include <dmac.h>
#include <SPI.h>
#define DMA_CH 0 //N° Canal du DMA
#define DMA_BUF_SIZE 32 //Taille mémoire DMA
uint32_t g_dma_buf2[DMA_BUF_SIZE];
SPI.begin();
SPI0->SPI_WPMR = 0x53504900; //Protection key
SPI0->SPI_IDR = 0x0000070F; //Desactivation interrupts
SPI0->SPI_MR = SPI_MR_MSTR | SPI_MR_PS; //SPI master
Serial.println("+++++");
pmc_enable_periph_clk(ID_DMAC);
uint32_t i;
uint32_t cfg;
dma_transfer_descriptor_t desc;
for (i = 0; i < DMA_BUF_SIZE; i++) {
g_dma_buf2[i] = i;
Serial.print(g_dma_buf2[i]);
dmac_init(DMAC);
dmac_set_priority_mode(DMAC, DMAC_PRIORITY_ROUND_ROBIN);
dmac_enable(DMAC);
cfg = DMAC_CFG_SOD_ENABLE | DMAC_CFG_AHB_PROT(1) | DMAC_CFG_FIFOCFG_ALAP_CFG; //Config registre CFG
dmac_channel_set_configuration(DMAC, DMA_CH, cfg);
desc.ul_source_addr = (uint32_t)g_dma_buf2;
desc.ul_destination_addr = SPI0->SPI_TDR;
desc.ul_ctrlA = DMAC_CTRLA_BTSIZE(DMA_BUF_SIZE) | DMAC_CTRLA_SRC_WIDTH_WORD | DMAC_CTRLA_DST_WIDTH_WORD;
desc.ul_ctrlB = DMAC_CTRLB_SRC_DSCR_FETCH_DISABLE | DMAC_CTRLB_DST_DSCR_FETCH_DISABLE | DMAC_CTRLB_FC_MEM2MEM_DMA_FC | DMAC_CTRLB_SRC_INCR_INCREMENTING | DMAC_CTRLB_DST_INCR_FIXED;
desc.ul_descriptor_addr = 0;
SPI_Enable(SPI0);
dmac_channel_multi_buf_transfer_init(DMAC, DMA_CH, &desc);
dmac_channel_enable(DMAC, DMA_CH);
Serial.println("*****");
while (!dmac_channel_is_transfer_done(DMAC, DMA_CH)) { Serial.print('X'); }
Se
Serial.print("SR : "); Serial.println(SPI0->SPI_SR, HEX);
Serial.print("TDR : "); Serial.println(SPI0->SPI_TDR, HEX);
Serial.print("PSR : "); Serial.println(PIOA->PIO_PSR, HEX); //PIO_SODR
Serial.print("OSR : "); Serial.println(PIOA->PIO_OSR, HEX);
Serial.println(DMAC->DMAC_CH_NUM[0].DMAC_SADDR , HEX);
Serial.println(DMAC->DMAC_CH_NUM[0].DMAC_DADDR, HEX);
Serial.println("-----");
I use mainly this example : https://ww1.microchip.com/downloads/en/Appnotes/Atmel-42291-SAM3A-3U-3X-4E-DMA-Controller-DMAC_ApplicationNote_AT07892.pdf#_OPENTOPIC_TOC_PROCESSING_d91e3076
And here is the datasheet of the µc : https://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-11057-32-bit-Cortex-M3-Microcontroller-SAM3X-SAM3A_Datasheet.pdf
You can see at the bottom of my code sevral prints, from them I had many idea : does the PIO could block the data ? Does the address PIO_PA26A_SPI0_MOSI could work ? Could the SPI block the data because conditions are not met ?
Any idea is welcomed, I'm on this for some time now.
