Send DHT-22 data to thingspeak using nodemcu esp8266 and arduino uno
I want to send sensor data to thingspeak using nodemcu esp8266 and arduino uno. So, the sensor only connect to arduino uno and i use serial communication between nodemcu esp8266 and arduino so that data from arduino can be read by nodemcu esp8266, and nodemcu esp8266 will send the data to thingspeak. I'm getting data on serial monitor but the data is not visible on thingspeak server. I have entered the credential code correctly. What should i do to make the sensor data visible on Thingspeak?
This is what I've done :
Code for Arduino Uno :
#include <DHT.h>
#define dhtPin 3
#define dhtType DHT22
DHT dht(dhtPin, dhtType);
  dht.begin();
  float t = dht.readTemperature();
  float h = dht.readHumidity();
  if (isnan(t)|| isnan(h)) {
    Serial.println("No Data");
    delay(2000);
  Serial.print("Temperature : ");
  Serial.print(t);
  Serial.print("Humidity : ");
  Serial.print(h);
  delay(5000);
Code for NodeMCU ESP8266 :
#include<ESP8266WiFi.h>
#include<WiFiClient.h>
#include<ESP8266HTTPClient.h>
#include <ThingSpeak.h>
String URL = "http://api.thingspeak.com/update?api_key=APIKEY&field1=";
  WiFi.disconnect();
  delay(2000);
  Serial.print("Start connection");
  WiFi.begin("SSID","PASSWORD");
  while((!(WiFi.status()==WL_CONNECTED))){
    Serial.print("..");
  Serial.println("Connected");
  if(Serial.available()>0){
    String data=Serial.readStringUntil('\n');
    Serial.println(data);
    int comma = data.indexOf(',');
    if(comma!=-1){
      float t = data.substring(0,comma).toFloat();
      float h = data.substring(comma+1).toFloat();
      Serial.print(t);
      Serial.println(h);
      sendData(t,h);
void sendData(float t, float h){
  WiFiClient client;
  HTTPClient http;
  String newUrl=URL+String(t)+"&field2="+String(h);
  http.begin(client,newUrl);
  int responsecode=http.GET();
  String data = http.getString();
  http.end();
  delay(5000);
Why not use a controller that can do both sensor reading and Thingspeak communication?
