Hi all,
I have found a tutorial on sending values using arduino to the android device:
http://allaboutee.com/2011/12/31/arduino-adk-board-how-send-data-from-the-board-to-the-android-device/
This is my current codes now:
Android:
package com.FYP.arduinotestreceivedata;
import java.io.FileDescriptor;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.util.Date;
import android.app.Activity;
import android.app.PendingIntent;
import android.content.BroadcastReceiver;
import android.content.Context;
import android.content.Intent;
import android.content.IntentFilter;
import android.os.Bundle;
import android.os.Handler;
import android.os.Message;
import android.os.ParcelFileDescriptor;
import android.util.Log;
import android.view.KeyEvent;
import android.view.View;
import android.widget.TextView;
import android.widget.ToggleButton;
import android.hardware.usb.UsbAccessory;
import android.hardware.usb.UsbManager;;
public class MainActivity extends Activity implements Runnable {
// Required to connect android with arduino
private static final String ACTION_USB_PERMISSION = "com.FYP.arduinotestreceivedata.USB_PERMISSION";
private UsbManager mUsbManager;
private PendingIntent mPermissionIntent;
private boolean mPermissionRequestPending;
UsbAccessory mAccessory;
ParcelFileDescriptor mFileDescriptor;
FileInputStream mInputStream;
FileOutputStream mOutputStream;
private TextView mResponseField;
private ToggleButton buttonLED;
// Require Methods to connect android with arduino
private final BroadcastReceiver mUsbReceiver = new BroadcastReceiver() {
@Override
public void onReceive(Context context, Intent intent) {
String action = intent.getAction();
if (ACTION_USB_PERMISSION.equals(action)) {
synchronized (this) {
UsbAccessory accessory = (UsbAccessory) intent
.getParcelableExtra(UsbManager.EXTRA_ACCESSORY);
if (intent.getBooleanExtra(
UsbManager.EXTRA_PERMISSION_GRANTED, false)) {
openAccessory(accessory);
// USB permission denied
} else if (UsbManager.ACTION_USB_ACCESSORY_DETACHED.equals(action)) {
if (accessory != null && accessory.equals(mAccessory)) {
// accessory detached
android.os.Process.killProcess(android.os.Process.myPid());
closeAccessory();
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
mUsbManager = (UsbManager) getSystemService(Context.USB_SERVICE);
mPermissionIntent = PendingIntent.getBroadcast(this, 0, new Intent(ACTION_USB_PERMISSION), 0);
IntentFilter filter = new IntentFilter(ACTION_USB_PERMISSION);
filter.addAction(UsbManager.ACTION_USB_ACCESSORY_DETACHED);
registerReceiver(mUsbReceiver, filter);
if (getLastNonConfigurationInstance() != null) {
mAccessory = (UsbAccessory) getLastNonConfigurationInstance();
openAccessory(mAccessory);
setContentView(R.layout.activity_main);
mResponseField = (TextView) findViewById(R.id.arduinoresponse);
buttonLED = (ToggleButton) findViewById(R.id.toggleButton1);
setupAccessory();
@Override
public Object onRetainNonConfigurationInstance() {
if (mAccessory != null) {
return mAccessory;
return super.onRetainNonConfigurationInstance();
@Override
public void onResume() {
super.onResume();
if (mInputStream != null && mOutputStream != null) {
// streams were not null");
return;
// streams were null");
UsbAccessory[] accessories = mUsbManager.getAccessoryList();
UsbAccessory accessory = (accessories == null ? null : accessories[0]);
if (accessory != null) {
if (mUsbManager.hasPermission(accessory)) {
synchronized (mUsbReceiver) {
if (!mPermissionRequestPending) {
mUsbManager.requestPermission(accessory,
mPermissionIntent);
mPermissionRequestPending = true;
// null accessory
@Override
public void onPause() {
super.onPause();
@Override
public void onDestroy() {
unregisterReceiver(mUsbReceiver);
super.onDestroy();
Handler mHandler = new Handler() {
@Override
public void handleMessage(Message msg) {
ValueMsg t = (ValueMsg)msg.obj;
// this is where you handle the data you sent. You get it by calling
// the getReading() function
mResponseField.setText("Flag: " + t.getFlag() + "; Reading: "
+ t.getReading());
private void setupAccessory() {
public void run() {
int ret = 0;
byte[] buffer = new byte[16384];
int i;
while (true) { // read data
try {
ret = mInputStream.read(buffer);
} catch (IOException e) {
i = 0;
while (i < ret) {
int len = ret - i;
if (len >= 1) {
Message m = Message.obtain(mHandler);
int value = (int) buffer[i];
// 'f' is the flag, use for your own logic
// value is the value from the arduino
m.obj = new ValueMsg('f', value);
mHandler.sendMessage(m);
i += 1; // number of bytes sent from arduino
private void openAccessory(UsbAccessory accessory) {
mFileDescriptor = mUsbManager.openAccessory(accessory);
if (mFileDescriptor != null) {
mAccessory = accessory;
FileDescriptor fd = mFileDescriptor.getFileDescriptor();
mInputStream = new FileInputStream(fd);
mOutputStream = new FileOutputStream(fd);
Thread thread = new Thread(null, this, "OpenAccessoryTest");
thread.start();
// Accessory opened
// failed to open accessory
private void closeAccessory() {
try {
mFileDescriptor.close();
} finally {
mFileDescriptor = null;
mAccessory = null;
@Override
public boolean onKeyDown(int keyCode, KeyEvent event) {
if (keyCode == KeyEvent.KEYCODE_BACK) {
return super.onKeyDown(keyCode, event);
Arduino:
#include <Max3421e.h>
#include <Usb.h>
#include <AndroidAccessory.h>
AndroidAccessory acc("Manufacturer",
"Model",
"Description",
"1.0",
"http://yoursite.com",
"0000000012345678");
int SBpin = 22;
int doorPin = 48;
int speedPin = 49;
int SBval = 0;
int DOORval = 0;
int SPEEDval = 0;
pinMode(SBpin,INPUT);
pinMode(doorPin, INPUT);
pinMode(speedPin, INPUT);
acc.powerOn();
byte msg[0]; // one byte
// int value = 10; // value to send,we'll increment and decrement this variable
if (acc.isConnected())
SBval = digitalRead(SBpin);
// DOORval = digitalRead(doorPin);
// SPEEDval = digitalRead(speedPin);
msg[0] = SBval;
acc.write(msg, 1);
I manage to send one values to the android device. How do i send more than 1 values to the android device and save it as a string or integer?
Thanks in advance.
Regards,
Wei Sheng
