I am trying to send a string over the serial port. I am very close but for some reason I get extra junk attached to front of the string. I could chop it off with a substring() but I would rather understand what it is and why its there. Thanks for any help.
input: <abc>
expected output:
current input is:a
current input is:b
current input is:c
full input is:abc
actual output:
current input is:⸮
current input is:⸮
current input is:⸮
current input is:a
current input is:b
current input is:c
current input is:>
full input is:⸮⸮⸮⸮⸮abc
The Arduino is fast, and serial input is slow. You are iterating through the while loop (3 times) with nothing to read and are adding a non printable character to the String. Use Serial.begin(115200) and there is less garbage. Add a small delay() to the while loop to allow the characters to arrive, and you see what you expect.
while (currentInput != PKG_END and currentIndex < MAXIMUM_INPUT_LENGTH )
delay(5);
Your entire approach can be improved. Don't use the String object , but rather a null terminated character array.
See Robin2's excellent tutorial on methods for receiving Serial data. There is an explicit example for the <> start and end characters.
You are sending the string (< marks the beginning of string, and > marks the end of string) from the InputBox of the Serial Monitor to the Arduino UNO. The UNO receives the string character-by-character and send them back to the OutputBox of the same Serial Monitor. Please, study the following Flow Chart of Fig-1 and try to write the codes without looking much into the codes that I have given in this post in Step-2.
Hopefully, you will be able to understand that the Flow Chart has very well represented the thoughts that you have behind this data exchange. Let us note that Flow Chart is a powerful tool that helps to visualize pictorially/geometrically the logic embedded within a Programming Problem.
1. Solution of your problem in the form of Flow Chart (tested)
Figure-1: Flow Chart describing data exchange between Serial Monitor and UNO
2. Arduino Codes for the Flow Chart of Step-1 (tested)
byte x;
char myArray[20] = "";
int i = 0;
bool flag1 = LOW;
if (Serial.available() > 0)
if (flag1 == HIGH) //< received
x = Serial.read();
if (x != '>')
Serial.print("current input is:");
Serial.println((char)x);
myArray[i] = x;
i++;
Serial.print("full input is:");
Serial.println(myArray);
if (Serial.read() == '<')
flag1 = HIGH;
3. Results of the execution of codes of Step-2
Figure-2:
