I need to send a two dimensional array to server using c arduino language . earlier i used to send through one dimensional array like this.
typedef struct {
String Name;
String addr;
String ttl;
}officeKownNetworks;
officeKownNetworks officeDevice;
JSONVar readings;
String KnownMacDetails() {
while(true) {
readings["addrDeviceUser"] = officeDevice.Name;
readings["addr"] = officeDevice.addr;
String jsonString = JSON.stringify(readings);
return jsonString;
and through spiffs i used to send that data to javascript
server.on("/clientsniffer", HTTP_GET, [](AsyncWebServerRequest *request){
String json = KnownMacDetails();
request->send(200, "application/json", json);
json = String();
and through promises or XML, I used to get data. but in the case of a 2-dimensional array, I am not getting how to send the data.
So basically, I have a loop where the Mac address is going to be saved in this array. of maclist [64] [3];
So how can I send that data to an array on the server, and how can I receive it through javascript? What parameter do I need to use?
Thank You
I am able to send a one-dimensional array to a server through JSON, but I need to know how to send a two-dimensional array to the server and receive it through Javascript.
