Sending a value with range (0-1023) in arduino to another arduino
Is there possible to not using Serial tx rx to do the communication? The serial communication between arduino is kind of trouble due to the maximum transmission size of 1 byte , and i need the value cost at least 2 byte.
you can transmit a 16bt integer in binary as two bytes and a float as four bytes
see post #11 of
Java to Arduino - transmit float as 4 bytes
hk199899:
You can use lowByte and highByte
  static int number = 0;
  Serial.write(highByte(number));
  Serial.write(lowByte(number));
  number++;
  if (number == 1024)
    number = 0;
  delay(100);
Recombine at the other side.
sterretje:
the combination of two byte is like this?
  byte higherbyte , lowerbyte;
  int number;
higherbyte = Serial.read();
  lowerbyte = Serial.read();
number = (higherbyte<<8)+lowerbyte;
some sample code
// encode 16 bit int as two bytes and decode
   Serial.setTimeout(60*60*1000ul);
// encode 16 bit unsigned integers data into two bytes (characters)
void intEncode(byte ch[2], const unsigned int data)
     ch[0]= (data>>8) & 0xff;   // top byte of data
     ch[1]=data & 0xff;         // lower 8 bits of data
// decode the above data
void intDecode(const byte ch[10], unsigned int *data)
    *data=(ch[0] << 8) | ch[1];
            unsigned int i, x={0},y;
            byte ch[2];
            Serial.print("enter an unsigned int ? ");
            x=Serial.parseInt();
            intEncode(ch, x);           // encode int as two bytes
            Serial.print("\nencoded characters ");
            for(i=0;i<2;i++)            // print the bytes
               { Serial.print(" " ); Serial.print(ch[i], HEX);}
            intDecode(ch, &y);          // decode bytes to an int
            Serial.print("\ndecoded data ");
            Serial.println(y);
a run gives
enter an unsigned int ? 67
encoded characters  0 43
decoded data 67
enter an unsigned int ? 7896
encoded characters  1E D8
decoded data 789625678
encoded characters  64 4E
decoded data 25678
