Sending data from Arduino to mySQL.
Hello everyone!
I have problem with sendind data from arduino UNO with wifi into mySQL database. Actually I know how to send data because when I put in my php file something like this:
$sql = "INSERT INTO data (test1,test2) VALUES ('54', '32')";
My database receive this record and I see it. Problem comes when I want to send to database for example int value
from my Arduino sketch. I'm able to send record to database but value is always 0 and I dont know why.
Here is my PHP file and Arduino sketch:
#include <SPI.h>
#include <WiFiNINA.h>
#include <WiFi.h>
char ssid[] = "***";        // your network SSID (name)
char pass[] = "***";    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
WiFiClient client;
IPAddress serverip(******************);
String data = "";
int t = 123;
 if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to Network named: ");
    Serial.println(ssid);                   // print the network name (SSID);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  printWifiStatus();
  data = "temp1=" + t;
if (client.connect(serverip, 80)) {
	Serial.println("--> connection ok\n");
	client.println("POST /mydatabase/test.php HTTP/1.1");
	client.println("Host: ******");
	client.print("Content-Length: ");
	client.println(data.length());
	client.println();
	client.print(data);
    Serial.println("Successfull");
    client.stop();
    Serial.println("--> finished transmission\n");
    else {
    Serial.println("--> connection failed\n");
//XXXXX
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  // print where to go in a browser:
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
And PHP :
<?php
$servername = "hostname";
$database = "databaseName";
$username = "user";
$password = "pass";
// Create connection
$conn = mysqli_connect($servername, $username, $password, $database);
// Check connection
if (!$conn) {
      die("Connection failed: " . mysqli_connect_error());
echo "Connected successfully";
$sql = "INSERT INTO data (test1) VALUES ('".$_POST["temp1"]."')";
if (mysqli_query($conn, $sql)) {
      echo "New record created successfully";
      echo "Error: " . $sql . "
" . mysqli_error($conn);
mysqli_close($conn);
So when I use code like this, record which come to database have always value of 0 instead of value of "t" which is 123.
Could you help me ?
instead of this:
data = "temp1=" + t ;
Try:
data = "temp1=" + String( t ) ;
6v6gt:
instead of this:
Try:
Still record in my database is 0.
Hit your php page from a browser. What do you have to send it there to get data into the db?
wildbill:
When i hit php file from broweser i get something like this:
Parse error: syntax error, unexpected '"', expecting '-' or identifier (T_STRING) or variable (T_VARIABLE) or number (T_NUM_STRING) in C:\xampp\htdocs\**** on line 15
So line 15 refer to this:
$sql = "INSERT INTO data (test1) VALUES ('$_POST["temp1"]')";
What was the string you used in the browser? I'd suggest that you need to get that working before you worry about the Arduino. Much easier to debug too.
wildbill:
I don't clearly understand what you want me to do. When i hit this php with my browser:
<?php
$servername = "localhost";
$database = "voik3";
$username = "voik3";
$password = "xxxxx";
// Check connection
if (!$conn) {
$sql = "INSERT INTO data (test1) VALUES ('54')";
I recieve record in mydatabase in column test1 with value of 54. So it is working fine. But i want to send variable value from arduino into this database so i put something like in my first post but it send 0 instead of value of "t"
To be able to type URL on a browser command line, I believe the HTTP method has to be GET not POST. GET is certainly easier for exactly this kind of trouble shooting and, in this case, I would consider changing to GET.
You need to pass a parameter to the page. You've hard coded it to be 54. You need something like this stolen example from w3schools:
/test/demo_form.php?name1=value1&name2=value2
And then you'll need the corresponding PHP to grab the parameter & use it in your SQL.
6v6gt:
wildbill:
After hitting this php in browser :
<?php
$username = "user";
$password = "pass";
// Check connection
if (!$conn) {
$sql = "INSERT INTO data (test1) VALUES ('".$_GET["temp1"]."')";
} else {
I put in browser something like this:
http://xxxx/test/demo_form.php?temp1=4
And my record with value 4 has been added to database. But how I have to change my Arduino code to post it from there?
please show your mysql table structure
