This is my first time trying to programmatically send an email.
I found examples of sending emails, but they all use "Sender Email".
outbound.mailhop.org doesn't use an email to authenticate, but rather a username.
I have another device that sends an email using this SMTP server (have no idea what method it uses), these are its settings:
Email Client Protocol: SMTP - Authenticated
Sender mail address : Seems like it can be anything, I have it set to a non-existant email address
Send Mail Server (SMTP): outbound.mailhop.org
Port No. (SMTP): 25
Account: username
Password: password
Here is my attempt at massaging Mobizt's ReadyMail library "Attachment.ino"
This is a new library, but his ESP_Email_Client looks similar in the way the SMTP server is set up. I'll use that one, if somebody tells me it's easier or at least something they can help me get running.
Or any other way. I just want to send a .txt file.
* The example to send message with attachment.
#include <Arduino.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#define ENABLE_SMTP // Allow SMTP class and data
#define ENABLE_DEBUG // Allow debugging
#define READYMAIL_DEBUG_PORT Serial
#define ENABLE_FS // Allow filesystem integration
#include "ReadyMail.h"
#define SMTP_HOST "outbound.mailhop.org"
#define SMTP_PORT 25
#define DOMAIN_OR_IP ""
#define AUTHOR_EMAIL "?????" // username and password required, not email
#define AUTHOR_PASSWORD "password" // password for outbound.mailhop.org account
#define RECIPIENT_EMAIL "my@email.com"
#define WIFI_SSID "WiFi SSID"
#define WIFI_PASSWORD "WiFi Password"
WiFiClientSecure ssl_client;
SMTPClient smtp(ssl_client);
#if defined(ENABLE_FS)
#include <FS.h>
File myFile;
#if defined(ESP32)
#include <SPIFFS.h>
#endif
#define MY_FS SPIFFS
const char *orangeImg = "iVBORw0KGgoAAAANSUhEUgAAAGQAAABkCAYAAABw4pVUAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAAEnQAABJ0Ad5mH3gAAAEASURBVHhe7dEhAQAgEMBA2hCT6I+nABMnzsxuzdlDx3oDfxkSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0iMITGGxBgSY0jMBYxyLEpP9PqyAAAAAElFTkSuQmCCjhSDb5FKG9Q4";
const char *blueImg = "iVBORw0KGgoAAAANSUhEUgAAAGQAAABkCAYAAABw4pVUAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAAEnQAABJ0Ad5mH3gAAAEASURBVHhe7dEhAQAgAMAwmmEJTyfwFOBiYub2Y6596Bhv4C9DYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJMSTGkBhDYgyJuZ7+qGdQMlUbAAAAAElFTkSuQmCC";
void fileCb(File &file, const char *filename, readymail_file_operating_mode mode)
switch (mode)
case readymail_file_mode_open_read:
myFile = MY_FS.open(filename, FILE_OPEN_MODE_READ);
case readymail_file_mode_open_write:
myFile = MY_FS.open(filename, FILE_OPEN_MODE_WRITE);
case readymail_file_mode_open_append:
myFile = MY_FS.open(filename, FILE_OPEN_MODE_APPEND);
case readymail_file_mode_remove:
MY_FS.remove(filename);
default:
file = myFile;
void createAttachment()
MY_FS.begin(true);
File file = MY_FS.open("/orange.png", FILE_WRITE);
file.print(orangeImg);
file.close();
file = MY_FS.open("/blue.png", FILE_WRITE);
file.print(blueImg);
file.close();
#endif
void smtpCb(SMTPStatus status)
if (status.progressUpdated)
ReadyMail.printf("ReadyMail[smtp][%d] Uploading file %s, %d %% completed\n", status.state, status.filename.c_str(), status.progress);
ReadyMail.printf("ReadyMail[smtp][%d]%s\n", status.state, status.text.c_str());
// The status.state is the smtp_state enum defined in src/smtp/Common.h
void addFileAttachment(SMTPMessage &msg, const String &filename, const String &mime, const String &name, FileCallback cb, const String &filepath, const String &encoding = "", const String &cid = "")
Attachment attachment;
attachment.filename = filename;
attachment.mime = mime;
attachment.name = name;
// The inline content disposition.
// Should be matched the image src's cid in html body
attachment.content_id = cid;
attachment.attach_file.callback = cb;
attachment.attach_file.path = filepath;
// Specify only when content is already encoded.
attachment.content_encoding = encoding;
if (cid.length() > 0)
msg.addInlineImage(attachment);
msg.addAttachment(attachment);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(300);
Serial.print("Connected with IP: ");
createAttachment();
ssl_client.setInsecure();
Serial.print(smtp.connect(SMTP_HOST, SMTP_PORT, DOMAIN_OR_IP, smtpCb, false));
if (!smtp.isConnected())
return;
smtp.authenticate(AUTHOR_EMAIL, AUTHOR_PASSWORD, readymail_auth_password);
if (!smtp.isAuthenticated())
return;
SMTPMessage msg;
msg.sender.name = "ReadyMail";
msg.sender.email = AUTHOR_EMAIL;
msg.subject = "ReadyMail Hello message with attachment";
msg.addRecipient("User", RECIPIENT_EMAIL);
String bodyText = "Hello everyone.\n";
msg.text.content = bodyText;
msg.text.transfer_encoding = "base64";
msg.html.content = "<html><body><div style=\"color:#00ffff;\">" + bodyText + "</div></body></html>";
msg.html.transfer_encoding = "base64";
addFileAttachment(msg, "orange.png", "image/png", "orange.png", fileCb, "/orange.png", "base64");
addFileAttachment(msg, "blue.png", "image/png", "blue.png", fileCb, "/blue.png", "base64");
smtp.send(msg);
Results:
Connecting to Wi-Fi......
Connected with IP: 192.168.xxx.xxx
ReadyMail[smtp][1] Connecting to outbound.mailhop.org...
0
Apparently, you can't use Port 25 with SSL. Any idea how to not use SSL with this code?
Any idea how to use account username and password?
I tried reading what documentation there is, but it seems like a language / translate barrier, plus my lack of understanding the basics.
