Sending float to I2C between nodemcu(master) and arduino minipro()
good day
I have a problem with this code, I tried for differents ways but don´t work
help me please
CODE MASTER
#include <Wire.h>
Wire.begin(D1,D2);
Serial.begin(9600); // start serial for output
Wire.requestFrom(2, 20); // request 20 bytes from slave device #2
String string, string1, string2;
do // slave may send less than requested
char c = Wire.read(); // receive a byte as character
string = string + c; //Keep saving whatever is comming
string1 = string.substring(0, 8); //slpit String from 0 to 8
string2 = string.substring(9); // Split from 9 to the End of String
} while (Wire.available());
Serial.print("Recieving float as String...");
Serial.print("Full String: ");
Serial.print(string);
Serial.print(" string 1: " );
Serial.print(string1);
Serial.print(" string 2: " );
Serial.print(string2);
Serial.println("");
Serial.println("");
Serial.println("");
CODE SLAVE
#include<Wire.h>
float x_lat = 32.12345;
float y_lng = -106.123456;
char wy[7];
char ix[8];
Wire.begin(2);
Wire.onRequest(Request);
void Request()
if (x_lat > y_lng)
//Converting float value to char
//The format (float, bytes, numbers of numbers after the decimal, char variable)
dtostrf(x_lat, 8, 5, ix);
Wire.write(ix); // appx 8 bytes
Serial.print(ix);
Wire.write(",");
Serial.print(",");
dtostrf(y_lng, 11, 6, wy);
Wire.write(wy); // appx 11 bytes
Serial.print(wy);
Wire.write("\n");
and I recive in a master port this
Full String: ⸮
string 1: ⸮
string 2:
thanks for your help
Please use code tags ("</>" button) when posting.
There is absolutely no reason to send Strings, or strings, or any formatted data by I2C. A floating point number takes up four bytes, so just send those four bytes as binary data and reassemble the number at the other end.
A union is great for doing that.
