So i'm trying to send an int number from c# trackbar to arduino. I've tried this:
private void trackBar1_Scroll(object sender, EventArgs e)
byte[] buffer = new byte[1];
buffer[0] = (byte)trackBar1.Value;
if (serialPort1.IsOpen)
serialPort1.Write(buffer, 0, 1);
label1.Text = trackBar1.Value.ToString();
It's send 1 byte to arduino, but because of that the int number is limited from 0-255. Can someone help me to send any int number i want. Thanks
Break the int into bytes, send the bytes individually, receive them on the Arduino and reconstruct the int by bitshifting and masking
Serial.begin(2000000);
while (!Serial);
byte lowByte = 0b00000001;
byte highByte = 0b10000000;
int result = highByte << 7 | lowByte;
Serial.println(result, BIN);
Why not send the value as text - it makes debugging easier.
Have a look at the examples in Serial Input Basics - simple reliable non-blocking ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable. It is what I use for Arduino to Arduino and Arduino to PC communication.
You can send data in a compatible format with code like this (or the equivalent in any other programming language)
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
...R
I've tried this before
C# code:
private void textBox2_TextChanged(object sender, EventArgs e)
serialPort1.WriteLine("vs_kp" +textBox2.Text);
Arduino Code:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
void serialEvent() {
while (Serial.available()) {
// get the new byte:
char inChar = (char)Serial.read();
// add it to the inputString:
if (inChar != '\n') {
mySt += inChar;
// if the incoming character is a newline, set a flag
// so the main loop can do something about it:
if (inChar == '\n') {
stringComplete = true;
if (stringComplete) {
// clear the string when COM receiving is completed
mySt = ""; //note: in code below, mySt will not become blank, mySt is blank until '\n' is received
stringComplete = false;
if (mySt.substring(0,5) == "vs_kp"){
kp = mySt.substring(5,mySt.length()).toFloat(); //get string after vs_kp
It works on the Arduino UNO but when i switch to the Leonardo, if i type in the Serial Monitor anything the Serial Monitor stop working. I asked about this and someone told me to avoid using string so now i'm try to sent an int directly.
They probably suggested that you do not use Strings (capital S) not strings(lowercase s) but I suspect that there was a much larger problem than that if typing into the Serial monitor it stopped working.
Note that Robin's solution uses strings (zero terminated arrays of chars) not Strings
dta1999:
I think things are mixed up here.
Differences between the Leonardo and the Uno have nothing to do with the String class. The USB system is a little different on the Leonardo so you need this to allow time for the serial port to be created
while (!Serial); // needed for Leonardo and Micro
// rest of the code
It is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. This can happen after the program has been running perfectly for some time. Just use cstrings - char arrays terminated with '\0' (NULL).
...R
