hello everybody, I am trying to send a sensor reading from one arduino to another using I2C, the reading is presented as an integer. I am planning to make the master work as a reader and the slave as sender, and connected all the wires correctly but cant seem to find a way to transfer an integer to byte and onec again to integer on the other side. can anyone please help me modify this code to get it working properly.
// Wire Master Reader
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Reads data from an I2C/TWI slave device
// Refer to the "Wire Slave Sender" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
Wire.requestFrom(2, 6); // request 4 bytes from slave device #2
while(Wire.available()) // slave may send less than requested
char c = Wire.read(); // receive a byte as character
Serial.print(c); // print the character
// Wire Slave Sender
// Sends data as an I2C/TWI slave device
// Refer to the "Wire Master Reader" example for use with this
#include <Wire.h>
Wire.begin(2); // join i2c bus with address #2
Wire.onRequest(requestEvent); // register event
delay(100);
// function that executes whenever data is requested by master
// this function is registered as an event, see setup()
void requestEvent()
Wire.write("hello "); // respond with message of 6 bytes
// as expected by master
