Thank you for taking the time to read this. I am sending a 3 digit number from one Arduino to the other with i2c .
I am ok with this the problems comes when I try to do something with the number because the number is sent one byte at a time I don't know how to put it together at the other end
so lets say I send "458" this would arrive as "4" "5" "8" could someone please tell me how make this back in to "four hundred and fifty eight"
[code// Wire Master Reader
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Reads data from an I2C/TWI slave device
// Refer to the "Wire Slave Sender" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
char t = 0;
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
Wire.requestFrom(8, 3); // request 3 bytes from slave device #8
while (Wire.available()) { // slave may send less than requested
char c = Wire.read(); // receive a byte as character
char c1 = Wire.read();
char c2 = Wire.read();
Serial.print(c); // print the character
Serial.print(c1);
Serial.print(c2);
Something like this...
int result = 0;
result *= 10;
result += (Wire.read() - 48);
Serial.println(result);
Nick Gammon has a great article where he covers pretty much everything about I²C. Take a look at the eighth message: "Send and receive any data type".
thanks martin but that dose not work it gives me a value of -30374
I have had a quick look at nick's post but unfortunately it is a bit advanced for my understanding Pieter but thanks
Please show how you incorporated Martin-X's suggestion into your code?
Are you certain that you are sending and receiving "458" as a 3 byte character string?
Can you post the slave code?
Martin-X:
Something like this...int result = 0;
result *= 10;
Magic numbers are bad. Instead of the 48, use the single character '0'. That way it is much more obvious what it is doing and you don't have to remember what 48 means.
int result = 0;
result *= 10;
result += (Wire.read() - '0');
int result = 0;
#include <Wire.h>
Wire.requestFrom(8, 3); // request 6 bytes from slave device #8
while (Wire.available()){
result *= 10;
the slave code is
// Wire Slave Sender
// Sends data as an I2C/TWI slave device
// Refer to the "Wire Master Reader" example for use with this
#include <Wire.h>
Wire.begin(8); // join i2c bus with address #8
Wire.onRequest(requestEvent); // register event
delay(100);
// function that executes whenever data is requested by master
// this function is registered as an event, see setup()
void requestEvent() {
Wire.write("458"); // respond with message of 3 bytes
// as expected by master
thanks
thank you martin and everyone for your help
this is the code I have ended up with my not be prefect but it works
int count =0;
int result = 0;
#include <Wire.h>
while (Wire.available()){ //waiting for value
result *= 10; // stuf to make number work ???
count ++; // wait untill i have 3 bytes
if (count == 3){
Serial.println(result); // check result
count=0; // reset counter
if (result == 500){ // check it all works
Serial.println("you got 500");
result = 0; // flush wire
my next problem is;
how do I mark this post as completed
You can edit the first post and change the title there to add [solved]
ho dear just when you think you have it sorted the problem I have is when send lets say "946" then all works as it should
but if I try to send data such as count then it displays different numbers hope some can help me with this
thanks
Master code
int count =0;
int result = 0;
#include <Wire.h>
if (count == 3){
Serial.println (result); // check result
slave code
#include <Wire.h> // for i2c comunication
int count = 1; // to count pulses from flow meter
Serial.println(count);
Wire.write(count);
// Wire.write("964");
count ++;
I would change your approach and send and receive the two bytes of an integer, rather than sending a character string and creating a numerical value from that string. Do some searching on "send integer with i2c".
The slave will break the previously declared and valued integer count into a high and low byte so the slave request event will look like this
void requestEvent()
byte buf [2];
buf [0] = count>> 8; //High byte of integer
buf [1] = count & 0xFF; //low byte of integer
Wire.write (buf, 2); //slave must send all bytes with only one Wire.write command
The master is going to request two bytes and reassemble them back into an integer with bit shifting. Again have the integer to receive declared.
Wire.requestFrom(slaveID, 2);
count = Wire.read() << 8 | Wire.read(); //first byte read is high byte
If you are unfamiliar with the bit shifting, you could use the arduino functions highByte(), lowByte() and word() to break and reconstruct the integer. See https://www.arduino.cc/en/Reference/HighByte
