I'm starting to learn how to work with Arduino and communication between a Python code and Arduino. So I decided to start with, what I thought to be a easy task, sending from user input from Python 2 values, one delay between Arduino LED (port 13) and servo angle. It didn't work and I couldn't find any answers, hope you can help me.
Arduino code :
#include <Servo.h>
const int ledPin = 13; // pin the LED is attached to
int incomingByte = 1000; // variable stores serial data
int pos = 0;
int incoming[2];
Servo myservo;
// initialize serial communication:
myservo.attach(9);
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
myservo.write(180);
digitalWrite(ledPin, LOW);
myservo.write(0);
if (Serial.available()>=2)
for (int i = 0; i < 1; i++)
incoming = Serial.read();
- digitalWrite(ledPin, HIGH);*
- delay(incoming[0]);*
- digitalWrite(ledPin, LOW);*
- myservo.write(incoming[1]);*
Python code :
import serial
import time
ser = serial.Serial('COM5', 9600, timeout=1)
user_input = '1'
while user_input != 'q': - user_input = input("'Blink time is or q = quit' : ")*
- servo_input = input("What position servo go? ")*
- byte_command = str.encode(user_input) *
- ser.write(byte_command) *
- servo_command = str.encode(servo_input)*
- ser.write(servo_command)*
- time.sleep(0.5) *
print('\nq entered. Exiting the program')
ser.close()
Thanks
