Sensor E18-D80NK not working
I am trying to work with arduino mega 2560 and sensor e18-d80nk. I have connected red with 5V, black with GND and yellow with pin 2. written following program
int Pin=2;
pinMode(Pin, INPUT);
int sensor = digitalRead(Pin);
if(sensor==HIGH)
Serial.println("Object Detected");
Serial.println("no Object detected");
Even no object is in front of sensor, it still shows as Object detected. I read somewhere that I need to connect 1k resistor between pin 2 and yellow wire. But no changes in result.
Can anyone help me with this?
Thanks in advance.
Try this instead
pinMode(Pin, INPUT_PULLUP);
Understand that the button states are reversed now, so that the logic is active low, i.e. button pressed is low, button released is high.
I tried your method, but still problem was there. I checked with sensor manufacturer, they have mentioned that sensor works on 6-36 VDC and arduino gives 5V, so I connected sensor to external supply of 12V. Now its working but signal also has 12V, so I can't connect it to arduino.
Can you suggest any better option for this?
Use a voltage divider
