I am building a small electrical car and I want to be able to monitor the distance traveled and store it on a SD card. So far I have been trying measuring the distance with an encoder and a photointerrupter attached to the axis of the wheels,(by measuring the number of turns of the axis) but the errors are coming up VERY large (double distance etc.)
I have tried with different number of holes (10, 6, 3) but it doesnt seem to work well.
Would you recommend trying with a hall effect sensor and some magnets? Is it in general more accurate?
Note that the spinning of the axis is not that large (about 150 RPM)
An analog output photo-interrupter perhaps?
You need to condition the outputs from an analog photo detector by using a schmitt-trigger to avoid
multiple transistions due to noise in the signal. This could be done in hardware or software, but it
has to be done.
A hall-switch sensor would be much simpler and robust.
