Hi, my lecturer has given me an LT3092 IC to connect to an Arduino Uno R3 board with some resistors and a sensor which resistance can increase if you press on it. And I am supposed to get an output on Arduino but I am not sure how to. Hope someone can help me
Post a link or schematic for the circuit board you are using. Without that, no-one can help very much.
What I can tell you is that you cannot plug a sensor into the power socket of an Uno. It will not work and may be damaged or cause damage.
No signals can be measured from your circuit board without a common ground, and you do not have one connected.
ouhh i see. the circuit board is basically just to solder the IC as its quite hard to connect it to a breadboard
this is the datasheet of the IC https://www.analog.com/media/en/technical-documentation/data-sheets/lt3092.pdf and where do I connect the ground though ![]()
A good question. Without a schematic for that circuit board, we can't help.
What is the class called and has the lecturer taught you how to read a voltage from a sensor?
Please include ALL hardware, component names and pin labels.
Thanks.. Tom...
Thanks.. Tom..
