Serial causing problems
this is my program:
/* * Blink * * The basic Arduino example. Turns on an LED on for one second, * then off for one second, and so on... We use pin 13 because, * depending on your Arduino board, it has either a built-in LED * or a built-in resistor so that you need only an LED. * * */
int ledPin = 13; // LED connected to digital pin 13
void setup() // run once, when the sketch starts { pinMode(ledPin, OUTPUT); // sets the digital pin as output
void loop() // run over and over again { digitalWrite(ledPin, HIGH); // sets the LED on Serial.println("Hello there"); delay(3000); // waits for a second digitalWrite(ledPin, LOW); // sets the LED off delay(1000); // waits for a second
When i load this program, my Arduino Mega grinds to a halt. when i remove the references to Serial it will happily flash the led. it is bound to be something really simple, but is there something someone can see which is causing my program to fail.
I just want to be able to send and receive characters from the Arduino Serial monitor to the board and back again.
all help appreciated.
What happens if you just remove the "Serial.prinltn", and leave in the "Serial.begin (...);" ?
Even if i leave just Serial.begin(9600) ,the arduino halts as well.
I do notice when i upload the program i get this output as well:
Couldn't determine program size: text data bss dec hex filename
Is that indicative of the problem?
I happened to be doing some ratting around and also found the following warnings during the compilation process:
/usr/share/arduino-0015/hardware/cores/arduino/wiring_serial.c: In function 'USART_RX_vect': /usr/share/arduino-0015/hardware/cores/arduino/wiring_serial.c:110: warning: 'USART_RX_vect' appears to be a misspelled signal handler
I googled this and found a post where someone (much more knowlegeable than me) indicated that if an interupt handler is not defined, then the arduino will constantly reset when the handler is called.
has anyone come across this in arduino-0015 and a mega board?
