Serial comm to iphone not working
I've been trying to make this project work for a while, and have made a little progress, but I am still missing something. I am trying to get my arduino to send vol + and vol - signals to my iphone. I can run the code in debug and it shows in the serial monitor. I can then run it is non-debug and the TX light shows transmission, but nothing happens on the iphone. I've double checked the wiring and am using the ipod breakout mini v3.
I used the approach from here: http://www.instructables.com/id/Simple-Ipod-Controller/
I used this wiring approach
And here is the code I'm using. Has anyone tried this before? I've tried different iphones/ipods with no success.
 Controls an iPod through the dock connector's serial interface.
 Tx (output 1) ---[1k]-------------iPod pin13 Rx
 		           |     -----iPod pin21 Accessory
 			   2k   500k
 Gnd-----------------------------------------iPod pin11 Ground
 				gnd
 				10k
 digital inputs 0-4 -------/push button/--- +5v
 2/13/11 changed to be a little more adaptable for further projects
 v0.3 - Added switches code
 v0.2 - Added DEBUG mode
 Added the DEBUG switch to be able to read the output without having an iPod connected.
 v0.1 - Initial code
 iPod mode 2 (simple iPod remote) only.
 Resources used:
 http://www.rosiedaniel.com/search/label/ipod
 http://stud3.tuwien.ac.at/~e0026607/ipod_remote/ipod_ap.html
 http://instruct1.cit.cornell.edu/courses/ee476/FinalProjects/s2007/awr8_asl45/awr8_asl45/index.html
 http://ipodlinux.org/wiki/Apple_Accessory_Protocol
 http://pinouts.ru/Devices/ipod_pinout.shtml
 Mode 2 Commands
 Command 		|Purpose
 0x00 0x00		|Button Released
 0x00 0x01		|Play
 0x00 0x02		|Vol+
 0x00 0x04		|Vol-
 0x00 0x08		|Skip>
 0x00 0x10		|Skip<
 0x00 0x20		|Next Album
 0x00 0x40		|Previous Album
 0x00 0x80		|Stop
#define NUMBUTTONS 4
// constants won't change. They're used here to set pin numbers:
const int buttonPin[NUMBUTTONS] = {6,7,8,9};     // the number of the pushbutton pin
// ipod mode 2 commands that we use
byte switchMode2[2]= {1,2};
byte buttonRelease[2]= {0,0};
byte playPause[2]= {0,1};
byte volUp[2]= {0,2};
byte volDown[2] = {0,4};
byte skipForward[2] = {0, 8};
int buttonCur[NUMBUTTONS];                         // the current reading from the input pin
int buttonPrev[NUMBUTTONS] = {LOW,LOW,LOW,LOW};    // the previous reading from the input pin
int i=0, j=0, k=0;
int debug=0;
// 2 for header + 1 for length + 1 for mode + 2 for command + up to 255 for params + 1 checkSum
byte msg[255+7]={0xff, 0x55};
// this isn't used, but if we wanted to go into ipod mode 4, we would fill this
// with the params needed and send it to the iPod
byte params[255];
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime[NUMBUTTONS] = {0,0,0,0};  // the last time the output pin was toggled
long lastPushedTime[NUMBUTTONS]={0,0,0,0};
long debounceDelay = 50;    // the debounce time; increase if the output flickers
long pushDelay=500;
  // setup serial port
  Serial.begin(19200);
  // setup input for buttons
  for(int i=0; i<NUMBUTTONS; i++){
    pinMode(buttonPin[i], INPUT);
  // setup the ipod for mode 2
  sendToPod(0, switchMode2, params, 0);
  // loop through all the buttons
  for(i=0;i<NUMBUTTONS;i++){
    // store the current button state
    buttonCur[i] = digitalRead(buttonPin[i]);
    // if it has changed, reset the debounce timer
    if (buttonCur[i] != buttonPrev[i])
      lastDebounceTime[i] = millis();
    // only wanna enter this section if the dbounce time has passed,
    // and if we didn't JUST push the button,
    // AND if the button is currently being pushed
    if ( millis() - lastDebounceTime[i] > debounceDelay && // debounce
      millis() - lastPushedTime[i] > pushDelay && // time out
      buttonCur[i]==HIGH) // being pushed
      lastPushedTime[i]= millis(); //reset timer
      switch(i){
        case(0): // play button
        sendToPod(2, playPause, params, 0);
        case(1): // pump up the volume button
        sendToPod(2, volUp, params, 0);
        case(2): // drop that baby down
        sendToPod(2, volDown, params, 0);
        case(3): // skip ahead !
        sendToPod(2, skipForward, params, 0);
      default: // no button
        sendToPod(2, buttonRelease, params, 0);
      // once we've sent the button push, we need to send the release!
    // save the reading.  Next time through the loop it'll be the buttonPrev:
    buttonPrev[i] = buttonCur[i];
// builds the msg that we want to send to the ipod
void sendToPod(byte mode, byte cmd[], byte parameter[], byte paramLength){
  // SIZE= 1 for mode + 2 for command + N for param
  msg[2]=(byte)1+2+paramLength;
  msg[3]=mode;
  msg[4]=cmd[0];
  msg[5]=cmd[1];
  // for now, length will always be zero.  if we entered mode 4 this might change...
  if(paramLength==0){
    msg[6]=0;
  else{
    for(j=0; j<paramLength; j++){
      msg[6+j]=parameter[j];
  // load up the checksum
  msg[6+paramLength]=getCheckSum(paramLength);
  // send the message to the ipod!
  for(j=0; j<7 + paramLength; j++){
    if(debug){
      Serial.print(msg[j], HEX);
      Serial.print(" ");
    else{
     Serial.print(msg[j]);
  if(debug)
    Serial.print("\n");
// calculates and returns the checksum of what is currently in the msg[] buffer
byte getCheckSum(byte paramLength){
  byte checkSum=0;
  for(k=2; k< 6+ paramLength; k++)
    checkSum=checkSum+msg[k];
  return 0x100 - (checkSum & 0xFF);
Any thoughts on my question here? I'm still stuck...
As you are following instructions from Instructables, why don't you post to their comments section.
It seems the logical thing to do, as the original author or one of the other people who built this, are in the best position to give you an answer
The problem might be just mechanical. I won't ask how you make the actual connection to the phone but, whatever it is,working on a D9 must be easier, and there is a cable available for iPhone<>RS232.
@roger - that is far too logical of an answer...that's why I didn't do it!
Seriously though, it didn't even occur to me. I'll drop a note over there and report back if I get this sorted.
