I am having trouble receiving information sent by my arduino Uno to my Leonardo via RX/TX connections. When using two arduino Unos however, the message passes just fine? Could this be due to the whole Serial1 thing on the arduino Leonardo? P.S. I have also noticed how when using both Unos, powering the receiving arduino provides current for both arduinos, whereas with the Leonardo, it does not provide current for the Uno sending it information.
Here are the codes I have uploaded to both arduinos:
There are two serial ports on the Leonardo, Serial and Serial1. The Serial instance is via the onboard USB-to-serial conversion process. Serial1 is via the RX and TX pins.
If you don't have anything connected to the RX and TX pins, using Serial1 is not going to accomplish anything.
Here's the tested Serial code for Arduino Leonardo:
Serial.begin(115200); //This pipes to the serial monitor
while(!Serial);
Serial1.begin(115200); //This is the UART, pipes to sensors attached to board
if( Serial.available() )
int inByte = Serial.read();
Serial1.write( inByte );
if( Serial1.available() )
int inByte = Serial1.read();
Serial.write( inByte );
Delta_G:
On your receiver, you might consider waiting until something is available to read before trying to read it.
Try the following codes (a modified version of your's):
char mystr[10];
Serial1.begin(9600); //it was missing
byte n = Serial1.available();
if (n != 0)
byte m = Serial1.readBytes(mystr,5); //blocking code
mystr[m] = '\0'; //you need to place null character at the end of char array
Serial.println(mystr);
//delay(1000); //timing is being controlled by sender
