Serial communication between Arduino Uno R4 and R3
I was working on a project using Arduino Uno R3. However, when I upgraded to Arduino Uno R4 wifi, the servomotor vibrates and doesn't work. Unfortunately, I haven't been using Arduino for long, so I don't know how to modify the code to work. So I'm trying to get the existing R3 to work with serial communication, but can it work with the code used for serial communication between the existing R3-R3 or R4-R4?
Welcome to the forum
The Serial interface on the R4 uses the USB connection to the PC for the Serial monitor and to upload code
If you want to use pins 0 and 1 on the R4 then use the Serial1 object
R4 has different IO pin specs than R3. Namely, output current limitations.
Check out https://docs.arduino.cc/resources/datasheets/ABX00087-datasheet.pdf, #11.3
and provide a connection diagram showing the board, servo, power supplies and whatever else is there
Be sure to power the servo independently, and connect the grounds.
I double-checked and found that I didn't connect the power properly. It works perfectly now. Thanks everyone!
