Hi!
I'm trying to make two esp32 able to send and receive messages from each other in communication via Serial, using Serial2 on the board.
Searching I can find several examples with Arduino UNO, but not with ESP32. I made an example here, but it's not working.
#include <HardwareSerial.h>
HardwareSerial SerialTwo(2);
SerialTwo.begin(9600);
String received = "";
while (SerialTwo.available())
received = SerialTwo.read();
SerialTwo.println(received);
SerialTwo.println("TEST");
delay(2000);
Circuit:
esp1 esp2
gnd to gnd
tx2 to rx2
rx2 to tx2
Can anyone give me any tips or material that explains this communication?
UnitA
HardwareSerial SerialTFMini( 1 );
HardwareSerial SerialBrain( 2 );
setup()
Serial.begin( SerialDataBits );
SerialBrain.begin( SerialDataBits );
SerialTFMini.begin( SerialDataBits, SERIAL_8N1, 27, 26 );
void fSendSerialToBrain( void *pvParameters )
struct stu_LIDAR_INFO pxLIDAR_INFO;
xSemaphoreGive ( sema_SendSerialToBrain );
String sSerial;
sSerial.reserve ( 300 );
for (;;)
xEventGroupWaitBits (eg, evtSendSerialToBrain, pdTRUE, pdTRUE, portMAX_DELAY);
// Serial.println ( " fSendSerialToBrain " );
if ( xSemaphoreTake( sema_SendSerialToBrain, xZeroTicksToWait ) == pdTRUE ) // grab semaphore, no wait
int CellCount = 1;
xSemaphoreTake( sema_LIDAR_INFO, xSemaphoreTicksToWait );
xQueueReceive ( xQ_LIDAR_INFO, &pxLIDAR_INFO, QueueReceiveDelayTime );
xSemaphoreGive( sema_LIDAR_INFO );
sSerial.concat( "<!," ); //sentence begin
sSerial.concat( String(ScanPoints) + "," );
for ( CellCount; CellCount <= ScanPoints; CellCount++ )
sSerial.concat( String(pxLIDAR_INFO.Range[CellCount]) + "," );
sSerial.concat( ">" ); //sentence end
// Serial.println ( sSerial );
SerialBrain.println ( sSerial );
// xEventGroupSetBits( eg, evtSendLIDAR_Info_For_ALARM );
// xSemaphoreGive ( sema_SendSerialToBrain );
sSerial = "";
vTaskDelete( NULL );
} // void fSendSerialToBrain( void *pvParameters )
Receiver:
HardwareSerial LIDARSerial ( 2 );
setup()
LIDARSerial.begin ( SerialDataBits, SERIAL_8N1, 26, 25 );
void fReceiveSerial_LIDAR( void * parameters )
bool BeginSentence = false;
sSerial.reserve ( StringBufferSize300 );
char OneChar;
for ( ;; )
EventBits_t xbit = xEventGroupWaitBits (eg, evtReceiveSerial_LIDAR, pdTRUE, pdTRUE, portMAX_DELAY);
if ( LIDARSerial.available() >= 1 )
while ( LIDARSerial.available() )
OneChar = LIDARSerial.read();
if ( BeginSentence )
if ( OneChar == ‘>’)
if ( xSemaphoreTake( sema_ParseLIDAR_ReceivedSerial, xSemaphoreTicksToWait10 ) == pdTRUE )
xQueueOverwrite( xQ_LIDAR_Display_INFO, ( void * ) &sSerial );
xEventGroupSetBits( eg, evtParseLIDAR_ReceivedSerial );
sSerial.concat ( OneChar );
if ( OneChar == ‘<’ )
sSerial = “”; // clear string buffer
BeginSentence = true; // found begining of sentence
} // while ( LIDARSerial.available() )
} //if ( LIDARSerial.available() >= 1 )
xSemaphoreGive( sema_ReceiveSerial_LIDAR );
} //void fReceiveSerial_LIDAR( void * parameters )
Hope the code helps.
google is always worth a quoogling (a quick googling)
https://www.google.de/search?q=esp32+hardware+serial+democode
There are three hardware supported serial interfaces on the ESP32 known as UART0, UART1 and UART2. Like all peripherals, the pins for the UARTs can be logically mapped to any of the available pins on the ESP32. However, the UARTs can also have direct...
best regards Stefan
system
Closed
April 28, 2022, 7:39am
4
