Serial communication issue between esp32 and uno nextion display
good evening gurus! I come to you with another serial communication question that I would desperately appreciate your help with. serial communication is something im still struggling/ working to understand better. thank you in advance.
concisely, i have an esp32 that is reading hx711 weight sensor readings and sending those readings to both the serial monitor and an arduino uno. the esp32 serial monitor displays the readings perfectly.
the arduino uno controls a nextion touch screen display that is meant to display the weight readings sent from the esp32. the nextion also displays voltage readings from the batteries. the voltage readings are acquired by the arduino uno rather than the esp32 like the weight readings are.
heres why that matters. when i press the update button to update the voltage readings, everything displays perfectly. but the weight readings from the esp32 only display on the nextion after i press the update button 2 times. the weight readings show up on the uno serial monitor everytime i press the update button, but upload to the nextion every other press.
posting this here and on nextion in case this is not a serial communication problem with the arduinos.
static boolean newDataReady = 0;
  const int serialPrintInterval = 0; //increase value to slow down serial print activity
esp32 load sensor data code
  // check for new data/start next conversion:
  if (LoadCell.update()) newDataReady = true;
  // get smoothed value from the dataset:
  if (newDataReady) {
    if (millis() > t + serialPrintInterval) {
      float i = LoadCell.getData();
      float lbs = ((i / 1000) * 2.2);
      String wtData = String(lbs);
      Serial2.println(wtData);
      Serial.print(F("Load_cell output val: "));
      Serial.println(lbs);
      newDataReady = 0;
      t = millis();
nextion display code
void b7PushCallback(void *ptr) {
  float lbs;
  if (espSerial.available() > 0) {
    espSerial.setTimeout(10);
    // Read The Incoming Data As A String
    String wtData = espSerial.readString();//Until('\n');
    float lbs = wtData.substring(0, 1).toInt();
    nexSerial.print("t5.txt=\"");
    nexSerial.print("\r\n");
    nexSerial.print(wtData); //(lbs, 2)
    nexSerial.print("\"");
    nexSerial.write(0xff);
    Serial.println(wtData);
    delay(100);
You will have to post both complete sketches.
How shall anybody analyse what is going on inside your code if not all of this code can be read?
You should add serial-printing on both microcontrollers to really see what is sended over the serial connection.
If you start the arduino-IDE a second time while a first IDE is already running you can adjust this second IDE to a different COM-Port.
This will enable to have two serial monitors active at the same time to see what is going on
Here is the basic Serial communication example you can start with.
why is there an additional test that millis() > that some value?
If you press a button requesting an update, why is time involved?
