I'm trying to use an Arduino Uno as a translator between two devices: a pixhawk flight controller and a Sagetech MXS transponder. The Arduino requests data from the pixhawk (gps, transponder mode, etc), receives the data, and translates the data into the proprietary Sagetech format.
It would be going just fine, but I can't figure out how to use two SoftwareSerial ports (I'm using the hardware serial port for debugging). Here's the code I'm using:
#include <NeoSWSerial.h>
#include <mavlink.h>
NeoSWSerial pixhawk_port(6, 7);
NeoSWSerial sagetech_port(2, 3);
pixhawk_port.begin(38400);
sagetech_port.begin(38400);
Serial.begin(57600);
while(!Serial){
mavlink_message_t msg_ident;
uint8_t len;
uint8_t buf[MAVLINK_MAX_PACKET_LEN];
uint8_t flight_id[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 6, 7};
uint8_t squawk[] = {1, 2};
void send_and_receive(NeoSWSerial& out_port, NeoSWSerial& in_port){
mavlink_msg_sagetech_adsb_parameters_pack(0, 0, &msg_ident, 0xFF, flight_id, squawk, 0xF0);
len = mavlink_msg_to_send_buffer(buf, &msg_ident);
out_port.write(buf, len);
in_port.listen();
mavlink_message_t msg;
mavlink_status_t status;
while(in_port.available()) {
uint8_t c = in_port.read();
if(mavlink_parse_char(MAVLINK_COMM_0, c, &msg, &status)){
if(msg.msgid == MAVLINK_MSG_ID_SAGETECH_ADSB_PARAMETERS){
Serial.println("ADSB msg");
if(msg.msgid == MAVLINK_MSG_ID_HEARTBEAT){
Serial.println("HB msg");
void listen(NeoSWSerial& port){
while(port.available()) {
uint8_t c = port.read();
send_and_receive(pixhawk_port, sagetech_port);
When I run my listen(port) method, I see constant heartbeats printed out on the serial monitor on both ports, so I know the wiring is correct. However, when I run my send_and_receive method, nothing is printed on the serial monitor.
I was thinking a possible problem would be my placement of the port.listen() method in send_and_receive.
If anyone could help me resolve this problem, I'd be very grateful.
