Serial communication = receiving wrong number
Hello!
I am trying to send a variable int (0-255) from an Node MCU V1 ESP 8266 to a Teensy 3.2.
My wiring is :
ESP8266 TX --> Teensy 9 (RX) (Serial 2 on Teensy)
ESP8266 RX --> Teensy 10 (TX) (Serial 2 on Teensy)
I have used the code in Serial input basics but I am getting very strange results.
Basically I am receiving the 3 same numbers: 52 then 48 then 10 and it starts again.
This is not at all what i am sending. I have tried sending a fixed value (400) and i still get the same result!
Help me please !!!
code ESP 8266 (sender)
int val = 0;
     Serial.print(440);
       Serial.print('\n');
code Teensy 3.2 (receiver)
#include <Audio.h>
#include <SD.h>
#include <SerialFlash.h>
// set this to the hardware serial port you wish to use
#define HWSERIAL Serial2
bool S1 = false;
int val = 0; //my value
  Serial.print("teensy ready");
  HWSERIAL.begin(9600);
  receiveS1();
  showS1 ();
void receiveS1() {
  if (HWSERIAL.available() > 0) {
    val = HWSERIAL.read();
    S1 = true;
  void showS1 () {
    if (S1 == true) {
     Serial.println("receving:");
      Serial.println(val, DEC);
      S1 = false;
You are printing the decimal value of what is received. IS this not what you are seeing?
val = HWSERIAL.parseInt();
I am receving : (with ```
receiving:
48
receiving:
52
receiving:
10
in a loop,
I should receive
440
440
440
will try this and report back tomorrow,
thanks :slight_smile:
the print() function turns your number into the ASCII representation so 440 turns into "440" which is a string of 3 chars with whose value is
'4' == 0x34 (hex) == 52 (decimal)
'0' == 0x30 (hex) == 48 (decimal)
and
'\n' == 0x0A (hex) == 10 (decimal)
So it looks like you are getting what you should be.
that makes a lot of sense! thanks!
What should i use to get 440?
Serial.println(val); // OR
Serial.parseInt();
You are receiving a SINGLE byte whose decimal value cannot exceed 256.
bytewise reading is like that:
void receiveS1() {
  if (HWSERIAL.available() >= 1) {
    byte Char = HWSERIAL.read();
    if (Char > 47 && Char < 58)   val = val * 10 + (Char - 48);
    else S1 = true;
Ok, I have it working now, thank you everyone.
Just a bit confused how that all works.
I have (to send)
     Serial.print(255);
     Serial.print('\n');
     delay(100);
     Serial.print(0);
     delay(100);
     Serial.print('\n');
and to receive :
void receiveS1() {
    else S1 = true;
  void showS1 () {
    if (S1 == true) {
      Serial.println(Char);
       Serial.println("val:");
      S1 = false;
In the serial monitor i get
receiving:
10
val:
255
receiving:
10
val:
0
So parseInt() returns my value but the byte reading
void receiveS1() {
    else S1 = true;
returns 10 (which if i understand is the linebreak? '\n' == 0x0A (hex) == 10 (decimal)
this is nonsence. use one of the options
void receiveS1() {
    val = HWSERIAL.parseInt(); //this will get complete integer number until not digit character comes
     S1 = true;
or
void receiveS1() {
    else S1 = true;
Yes, I realised this now.
Thank you
