Serial communication
Please help me, I still learning arduino programming. I made this code through researching.
This code works fine except for one area.... when there is something being printed to the LCD like "ERROR 03" or simply printing " " the solarAmps and solarVolts will stop updating. They can just stop like if it was 2.3 is stays like that but everything else runs well. These values are being sent by another Arduino nano through Serial. The two Nanos are running at same baud rate.
#include <avr/io.h>
#include <avr/interrupt.h>
#include <Wire.h>
#include <avr/wdt.h>
// Define constants and pin mappings
const int LED_PIN = LED_BUILTIN;
const int BUZZER_PIN = 6;
const int EGS002_POWER_PIN = 8;
const int FAULT_LED_PIN = 9;
const int MPPT_LED_PIN = 10;
const int MPPT_FAN_PIN = 11;
const int STANDBY_PIN = 12;
const int OUTPUT_RELAY_PIN = 7;
const int SHUT_DOWN_PIN = 4;
const int FAN_PIN = 3;
const int FAN_SENSE_PIN = 5;
const int BUTTON_SENSE_PIN = 2;
const int MPPT_OFF_PIN = A0;
const int TEMP_PIN = A1;
const int BATT_PIN = A2;
const int AC_CURR_PIN = A3;
const int AC_VOLTS_PIN = A7;
const long MINUTE = 60000;
const long INTERVAL = 1000;
const long MPPT_INTERVAL = 1000;
const char power[] = "power";
// Define global variables
bool inverterPower = false;
bool newData = false;
bool fanError1 = false;
bool fanError2 = false;
bool lowBattWarning = false;
bool buzzerEnabled = false;
bool dischargedBelow20 = false;
bool mpptState = false;
bool error = false;
bool lowVoltsWarning = false;
bool lowBatt = false;
bool highBatt = false;
bool tempError = false;
bool fanOn = false;
bool opVoltsError = false;
bool overLoad = false;
bool overCurr = false;
bool dispError = false;
int buzzerState = LOW;
int ledState = LOW;
int mpptLedState = LOW;
int lbw = 0;
int acLowError = 0;
int acHighError = 0;
int ovLdErr = 0;
int ovLdTout = 0;
int lowBattCut = 0;
int fanError = 0;
int fanState2;
int mpptFanState = 0;
int button;
int averageCount = 0;
int acVolts = 0;
int temperature = 0;
int acCurr = 0;
float battVolts = 0.0;
float solarVolts = 0.0;
float solarAmps = 0.0;
float tempValue = 0.0;
float ampsSum = 0.0;
float voltsSum = 0.0;
float avSolarVolts = 0.0;
float avSolarAmps = 0.0;
unsigned long lastSDT = 0;
unsigned long previousMillis = 0;
unsigned long mpptPrevMillis = 0;
unsigned long onDuration = 200;
unsigned long offDuration = 200;
unsigned long rememberTime = 0;
unsigned long mpptTimer = 0;
unsigned long acVoltsTimer = 0;
unsigned long voltsErrorShut = 0;
unsigned long fanTimer = 0;
unsigned long lcdRefreshTimer = 0;
unsigned long lowBattShut = 0;
unsigned long lastFilterUpdate = 0;
unsigned long resetTimer = 0;
const unsigned filterUpdateInterval = 100;
byte batt[] = { 0b01110, 0b11011, 0b11111,
                0b11111, 0b11111, 0b11111, 0b11111, 0b11111
byte solar[] = { 0b11111, 0b10101, 0b11111,
                 0b10101, 0b11111, 0b10101, 0b10101, 0b11111
byte acOut[] = { 0b01010, 0b01010, 0b11111, 0b11111, 0b01110, 0b00100, 0b00100, 0b00100 };
byte tempy[] = { 0b00100, 0b01010, 0b01010, 0b01110, 0b01110, 0b11111, 0b11111, 0b01110 };
byte load[] = { 0b00100, 0b00100, 0b00100, 0b11111, 0b01110, 0b00100, 0b11111, 0b11111 };
byte ampsChg[] = { 0b00010, 0b00100, 0b01000, 0b11111, 0b00010, 0b00100, 0b01000, 0b00000 };
LiquidCrystal_I2C lcd(0x27, 16, 4);
  // Initialize pins and peripherals
  analogReference(EXTERNAL);
  pinMode(LED_PIN, OUTPUT);
  pinMode(BUZZER_PIN, OUTPUT);
  pinMode(EGS002_POWER_PIN, OUTPUT);
  pinMode(FAULT_LED_PIN, OUTPUT);
  pinMode(MPPT_LED_PIN, OUTPUT);
  pinMode(STANDBY_PIN, OUTPUT);
  pinMode(OUTPUT_RELAY_PIN, OUTPUT);
  pinMode(SHUT_DOWN_PIN, OUTPUT);
  pinMode(FAN_PIN, OUTPUT);
  pinMode(FAN_SENSE_PIN, INPUT);
  pinMode(BUTTON_SENSE_PIN, INPUT);
  pinMode(MPPT_OFF_PIN, OUTPUT);
  pinMode(TEMP_PIN, INPUT);
  pinMode(BATT_PIN, INPUT);
  pinMode(AC_CURR_PIN, INPUT);
  pinMode(AC_VOLTS_PIN, INPUT);
  pinMode(MPPT_FAN_PIN, INPUT);
  digitalWrite(MPPT_OFF_PIN, HIGH);
  lcd.init();
  lcd.backlight();
  setupDisplay();
  fanLocked();
  //wdt_enable(WDTO_4S);
  if (!mpptState) {
    solarVolts = 0.0;
    solarAmps = 0.0;
    lcd.setCursor(11, 0);
    lcd.print(solarVolts, 1);
    lcd.setCursor(7, 2);
    lcd.print(solarAmps, 1);
  static unsigned long opvTimer;
  static unsigned long resetOffSerial;
  if (millis() - resetOffSerial > 5000) {
    digitalWrite(MPPT_OFF_PIN, LOW);
  if (battVolts < 29 && !lowBatt && !tempError && !opVoltsError && !overCurr && !overLoad && !fanError1) {
    error = false;
    lcd.backlight();
  loopDisplay();
  readings();
  if (button == 0) {
    outputVoltageMonitor();
    outputLoadMonitor();
  temperatureMornitor();
  mpptCharger();
  buttonPowerOff();
  if (inverterPower == 0) {
    acVoltsTimer = millis();
  if (!opVoltsError) {
    voltsErrorShut = millis();
  fanState2 = digitalRead(FAN_SENSE_PIN);
  mpptFanState = digitalRead(MPPT_FAN_PIN);
  //Serial.print("voltsErrorShut = ");
  //Serial.println(mpptState);
  //Serial.print("opVoltsError = ");
  //Serial.println(opVoltsError);
  //Serial.print("mill-fantimer = ");
  //Serial.println(millis()-fanTimer);
  if (button == 0 && (millis() > 10000)) {
    if (!error) {
      InverterOn();
      batteryMonitor();
      // errorDisplay();
  if (buzzerEnabled) {
    buzzer();
    digitalWrite(FAULT_LED_PIN, digitalRead(BUZZER_PIN));
  if (!buzzerEnabled && button == 0) {
    noBuzzer();
  if (millis() - lcdRefreshTimer > 10 * MINUTE) {
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.write(0);
    lcd.setCursor(9, 0);
    lcd.write(1);
    lcd.setCursor(0, 1);
    lcd.write(2);
    lcd.setCursor(9, 1);
    lcd.write(3);
    lcd.setCursor(-4, 2);
    lcd.write(4);
    lcd.setCursor(5, 2);
    lcd.write(5);
    lcdRefreshTimer = millis();
// Custom functions
void readings() {
  unsigned long currentTime = millis();
  if (currentTime - lastFilterUpdate >= filterUpdateInterval) {
    lastFilterUpdate = currentTime;
    float battValue = (analogRead(BATT_PIN) * 3.3 / 1024) * 15.44;
    battVolts = (battVolts * 0.9) + (battValue * 0.1);
    float acValue = (analogRead(AC_VOLTS_PIN) * 3.3 / 1024) * 174.4967;
    acVolts = (acVolts * 0.9) + (acValue * 0.1);
    int acCurrValue = (analogRead(AC_CURR_PIN));
    //acCurrValue = acCurrValue;
    acCurrValue = map(acCurrValue, 0, 1023, 0, 2400);
    acCurrValue = map(acCurrValue, 0, 2400, 0, 100);
    acCurr = (acCurr * 0.9) + (acCurrValue * 0.1);
    tempValue = (analogRead(TEMP_PIN) * 3.3 / 1024);
    tempValue = (tempValue * 0.9) + (tempValue * 0.1);
    float resistance = 14000 * (1 / (tempValue / 3.3) - 1);
    temperature = 1 / (0.001129833 + (0.000234848 * log(resistance)) + (0.000000085663 * pow(log(resistance), 3)));
    temperature = temperature - 273.15;
    temperature = temperature + 8;
void batteryMonitor() {
  // low voltage warning
  if (battVolts < 22 && !dischargedBelow20) {
    lowVoltsWarning = true;
  } else if (battVolts >= 23) {
  if (lowVoltsWarning) {
    onDuration = 2000;
    offDuration = 200;
    buzzerEnabled = true;
  if (battVolts < 20) {
    dischargedBelow20 = true;
    //lowVoltsWarning = true;
  // high voltage cut off
  if (battVolts >= 30) {
    highBatt = true;
  else if (battVolts <= 28.4) {
    highBatt = false;
  if (highBatt) {
    InverterOff();
    onDuration = 200;
    offDuration = 200;
    digitalWrite(FAULT_LED_PIN, HIGH);
  //low voltage cut off
  if (!lowBatt)lowBattShut = millis();
    lowBatt = true;
  } else if (battVolts > 23) {
    lowBatt = false;
  if (lowBatt) {
    InverterOff();
    if (millis() - lowBattShut > 5000) {
      lcd.noBacklight();
//temperature monitor
void temperatureMornitor() {
  if (temperature > 60) {
    tempError = true;
  } else if (temperature < 55) {
    tempError = false;
  if (tempError) {
    InverterOff();
    onDuration = 200;
    offDuration = 200;
  if (temperature >= 55 && acCurr < 50) {
    analogWrite(FAN_PIN, 5);
    fanOn = 1;
  } else if (temperature <= 50 && temperature > 45 && acCurr < 50) {
    analogWrite(FAN_PIN, 50);
    fanOn = 1;
  } else if ((temperature <= 45 && temperature > 40)) {
    analogWrite(FAN_PIN, 100);
    fanOn = 1;
  } else if (temperature < 45 && mpptFanState == 1) {
    fanOn = 1;
  } else if (temperature <= 35 && mpptFanState == 0) {
    fanOn = 0;
    digitalWrite(FAN_PIN, 1);
  if (acCurr >= 50 && temperature > 37) {
    analogWrite(FAN_PIN, 30);
    fanOn = 1;
  if (fanOn == 0) {
    fanTimer = millis();
  if (millis() - fanTimer > 10000) {
    if (fanState2 == 1 && fanOn == 1) {
      fanError2 = true;
      if (fanError2) {
        digitalWrite(FAULT_LED_PIN, 1);
        error = true;
        onDuration = 200;
        offDuration = 200;
//output voltage mornitor
void outputVoltageMonitor() {
  if (millis() - acVoltsTimer > 10000) {
    if ((acVolts <= 165) || (acVolts >= 260)) {
      opVoltsError = true;
    if (opVoltsError) {
      //dispError = true;
      onDuration = 500;
      offDuration = 500;
      //error = true;
    if (millis() - voltsErrorShut > 15000) {
      InverterOff();
      digitalWrite(SHUT_DOWN_PIN, HIGH);
//output Load Monitor
unsigned long overLoadTimer = 0;
unsigned long shortCircuitTimer = 0;
void outputLoadMonitor() {
  if (!overLoad) {
    overLoadTimer = millis();
  if (acCurr >= 75 && acCurr <= 85) {
    overLoad = true;
    error = true;
  } else if (acCurr < 75 || acCurr > 85) {
    overLoad = false;
    //buzzerEnabled = false;
  if (overLoad) {
    onDuration = 1000;
    offDuration = 1000;
    if (millis() - overLoadTimer > 10000) {
      InverterOff();
      delay(2000);
  if (!overCurr) {
    shortCircuitTimer = millis();
  if (acCurr >= 90) {
    overCurr = true;
    error = true;
  } else if (acCurr < 90) {
    if (millis() - shortCircuitTimer > 10000) {
      overCurr = false;
  if (overCurr) {
    InverterOff();
    onDuration = 50;
    offDuration = 50;
void loopDisplay() {
  if (acVolts <= 10)acVolts = 0;
  if (solarAmps < 0)solarAmps = 0.0;
  if (averageCount >= 16) {
    avSolarVolts = voltsSum / averageCount;
    voltsSum = 0.0;
    avSolarAmps = ampsSum / averageCount;
    ampsSum = 0.0;
    averageCount = 0;
  voltsSum += solarVolts;
  ampsSum += solarAmps;
  averageCount++;
  lcd.setCursor(2, 0);
  lcd.print(battVolts, 1);
  lcd.setCursor(2, 1);
  lcd.print(acVolts);
  lcd.setCursor(-2, 2);
  lcd.print(acCurr);
  lcd.setCursor(11, 1);
  lcd.print(temperature);
  if (acCurr < 100) {
    lcd.setCursor (0, 2);
    lcd.print(" ");
  if (acCurr < 10) {
    lcd.setCursor (-1, 2);
    lcd.print(" ");
  if (acVolts < 100) {
    lcd.setCursor (4, 1);
    lcd.print(" ");
  if (acVolts < 10) {
    lcd.setCursor (3, 1);
    lcd.print(" ");
  if (avSolarAmps < 10) {
    lcd.setCursor(10, 2);
    lcd.print("  ");
  if (avSolarVolts < 10) {
    lcd.setCursor(14, 0);
    lcd.print("  ");
  if (newData) {
    lcd.print(avSolarVolts, 1);
    lcd.print(avSolarAmps, 1);
void mpptCharger() {
  static unsigned long mpptTimer;
  if (Serial.available() >= sizeof(solarAmps) + sizeof(solarVolts) + 2) {
    char bytes[sizeof(solarAmps) + sizeof(solarVolts) + 2];
    Serial.readBytes(bytes, sizeof(solarAmps) + sizeof(solarVolts) + 2);
    newData = true;
    mpptState = true;
    if (bytes[0] == 0x01 && bytes[sizeof(solarAmps) + sizeof(solarVolts) + 1] == 0x04) {
      memcpy(&solarAmps, bytes + 1, sizeof(solarAmps));
      memcpy(&solarVolts, bytes + 1 + sizeof(solarAmps), sizeof(solarVolts));
    lastSDT = millis();
    mpptTimer = millis();
    if (solarAmps > 0.01) {
      mpptIndicator();
      digitalWrite(MPPT_LED_PIN, 0);
  else if (millis() - lastSDT > 2000) {
    solarAmps = 0.0;
    solarVolts = 0.0;
    newData = false;
    mpptState = false;
  int button = digitalRead(BUTTON_SENSE_PIN);
  if (button == 1 & millis() > 20000) {
    if (millis() - mpptTimer > 10000) {
      if (!inverterPower) {
        digitalWrite(SHUT_DOWN_PIN, HIGH);//(MPPT_OFF_PIN, 1);
void buttonPowerOff() {
  static unsigned long buttonState;
  if (button == 0) buttonState = millis();
  if (button == 1 && millis() - buttonState < 3000) {
    digitalWrite(BUZZER_PIN, 1);
  if (millis() - buttonState > 5000) {
    digitalWrite(BUZZER_PIN, 0);
    InverterOff();
  if (millis() - buttonState > 20000) {
    if (!mpptState) {
void InverterOn() {
  //lcd.backlight();
  digitalWrite(STANDBY_PIN, 1);
  digitalWrite(EGS002_POWER_PIN, 1);
  digitalWrite(FAULT_LED_PIN, LOW);
  inverterPower = true;
  if (acVolts > 170) {
    inverterIndicator();
    digitalWrite(OUTPUT_RELAY_PIN, 1);
void InverterOff() {
  digitalWrite(STANDBY_PIN, 0);
  digitalWrite(EGS002_POWER_PIN, 0);
  digitalWrite(LED_PIN, 0);
  digitalWrite(OUTPUT_RELAY_PIN, 0);
void inverterIndicator() {
  if (currentMillis - previousMillis >= INTERVAL) {
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(LED_PIN, ledState);
void mpptIndicator() {
  unsigned long mpptMillis = millis();
  if (mpptMillis - mpptPrevMillis >= MPPT_INTERVAL) {
    mpptPrevMillis = mpptMillis;
    if (mpptLedState == LOW) {
      mpptLedState = HIGH;
      mpptLedState = LOW;
    digitalWrite(MPPT_LED_PIN, mpptLedState);
void fanLocked() {
  int fanState = digitalRead(FAN_SENSE_PIN);
  if (fanState == 1) {
    fanError1 = true;
    onDuration = 200;
    offDuration = 200;
      buzzer();
    // while (true);
void setupDisplay() {
  lcd.print("****************");
  lcd.setCursor(-4, 3);
  digitalWrite(LED_PIN, 1);
  delay(200);
  digitalWrite(MPPT_LED_PIN, 1);
  delay(200);
  delay(200);
  digitalWrite(FAULT_LED_PIN, 0);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  lcd.clear();
  lcd.createChar(0, batt);
  lcd.createChar(1, solar);
  lcd.createChar(2, acOut);
  lcd.createChar(3, tempy);
  lcd.createChar(4, load);
  lcd.createChar(5, ampsChg);
  lcd.write(0);
  lcd.write(1);
  lcd.write(2);
  lcd.write(3);
  lcd.write(4);
  lcd.write(5);
  delay(2000);
void buzzer() {
  if (buzzerState == LOW) {
    if ((millis() - rememberTime) >= onDuration) {
      buzzerState = HIGH;
      rememberTime = millis();
    if ((millis() - rememberTime) >= offDuration) {
      buzzerState = LOW;
  digitalWrite(BUZZER_PIN, buzzerState);
void noBuzzer() {
  digitalWrite(BUZZER_PIN, LOW);
void errorDisplay() {
  if (lowVoltsWarning || highBatt || lowBatt || tempError || fanError1 || fanError2 || opVoltsError || overLoad || overCurr) {
    error = true;
  } else if (!lowVoltsWarning && !highBatt && !lowBatt && !tempError && !fanError1 && !fanError2 && !opVoltsError && !overLoad && !overCurr) {
    error = false;
  if (error) {
      lcd.setCursor(-1, 3);
      lcd.print("ERROR [64]");
    else if (highBatt) {
      lcd.print("ERROR [03]");
    else if (lowBatt) {
      lcd.print("ERROR [04]");
    else if (tempError) {
      lcd.print("ERROR [27]");
    else if (fanError2) {
      lcd.print("ERROR [61]");
    else if ((acVolts < 165) && (millis() - acVoltsTimer > 10000)) {
      lcd.print("ERROR [58]");
    else if (acVolts > 260) {
      lcd.print("ERROR [06]");
    else if (overLoad) {
      lcd.print("ERROR [67]");
    else if (millis() - overLoadTimer > 10000) {
      lcd.print("ERROR [07]");
    else if (overCurr) {
      lcd.print("ERROR [05]");
    else if (fanError1) {
      lcd.print("ERROR [01]");
  else if (!error) {
    lcd.print("                ");
Thank you in advance.
The sketch is pretty long, and with a bit of unnecessary things (like some curly brackets surrounding a single statement) so you better give it a good formatting to let you (and us) an easier code analysis. To do it, open the sketch with your IDE and use Ctrl-T command to let it "auto-format" the code. Then edit your first post and replace the whole code with the new "well-formatted" one.
Thanks.
Where did you research and find this false information? YouTube, Instructables, ChatGPT, and so many more "projects" are full of false information.
The "lowest" LCD location is (0,0)... update your program to this.
Your sketch has five seconds of delay() calls in every iteration. In your research, you should have read "delay()" is to be avoided and independent event timing will require using a timer, such as "millis()"
I see you are using millis(); and "delay()" is only inside "setup()"
Update your sketch with the LCD information and show the corrected sketch.
Thank you for reply... with my LCD module, if I want to print at (0, 3) as it supposed to be, it doesn't print on column 0 row 3. I searched somewhere I can't remember where they told me to try (-1, 3) and it worked fine. Can than be my problem?
You never use WDT or ISR/interrupts.
Probably because there are only two rows.
Do what you want. I tried.
[edit]
Do you indeed have a 4 line display?
Have you tried running the library example? There are several with the same name. Do you know which one you are using?
Yes it's a 16×4 LCD, the library is by Frank de Brabander
I would recommend that you use the currently best available library for the i2c lcd modules which is Bill Perry's hd44780.h. It is available through the library manager.
It will auto configure the i2c address and the pin configuration. There is a comprehensive diagnostic sketch as part of the library if there are any issues. Reference material is here.
Install the library, using the library manager. You will be able to print on all rows at columns 0-15 without strange negative locations,
Once you get the display working correctly you can move on to your serial issues.
Thanks my friend! Will do that and update you
That is a false notion fit for interpreter code.
The compiler generates machine code that has no brackets, braces, parenthesis at all. It optomizes all of that and more.
Braces put in to make source more definite and clear do not slow the what runs even a tiny bit.
That's not to that the OP's source isn't self-slowing. It is in many ways but you don't need to get down to what doesn't matter to show it.
I'm only stating this to help you not make brevity the enemy of clarity in your own code. Dig more into what the compiler does since sometimes being definite can make a difference in what the compiler generates and save you tracking a bug down!
So the compiler optimizes those out.
I see that Serial is set at 9600 baud making the Nano-Nano connection into a bottleneck.
Default Serial is 1 start bit, 8 data bits, 1 stop bit. 9600 baud is 960 chars per second, over 1 ms per char transmitted!
Nuff sed?
You should be able to get at least 5760 cps if the seril cable isn't long. 115200 baud isn't a stretch but try for 200000 and test for reliability and if that works then try faster!
Are you serious? I know that, and if you read and understand my post I was just talking about source readability and a correct/standard indentation, not about code execution speed.
Posting here a clearly and easily understandable code is the basic behaviour required for more users trying to help the OP. I thought it was clear...
Kudos on using timers though i did not check all of that.
note that last i saw, Arduino Nano has no FPU and is limited to 32 bit floating point. To that end, floats slow down Arduinos Badly!
Your use of floats may work well on chalkboard, paper, calculator and PC using 64 bit floating point but loses more precision than you might realize with 32 bit floats. It also slows down what is already slow!
I'm not going to type out the whole how and why but....
you could do faster and more precise calculating with long or long long integers using very small work units (like micrometers instead of meters kind of work units (as opposed to display units) and avoiding boiled-down factors.
Always multiply, then divide at the end to achieve the highest precision, making sure that your variables can hold the largest value calculated before the divide. Do it right and you may only need one big integer! Arduino lets us use 64 bit long long variables good for - to + 19 places of 0 to 9. Use small enough work units and you can lose places in the final divide that are below anything you need in most cases, it's always possible to make a case where that's not enough but usually not necessary!
I have just used HD44780 library and the problem has gone!!!! Thank you and everyone who took their time to help.
God bless you!
Yes, but the fact of unused, advanced programming indicate a gap of understanding.
What do you mean? I go sleep and when I get back your unspecific reply might as well be from a big Magic 8 Ball with room for more words.
As you say, the program is functioning just as you wrote it to do.
If you want the program to be much more active in all functions, then do not try to do a complete function all at once.
For instance, your data from the other Arduino should be read as a single byte when it becomes available, and saved in a work area until a complete message has been received. and only then processed. Let loop() run as fast as possible. When you have discovered a complete message as been read, only then process the message.
The same logic may be possible with your other functions.
In some cases, many really, processing the data as it arrives will give answers when or soon after the last data arrives. I did a lot with that in the 80's and 90's when computers were slower and my code looked fast and in some cases made possible what others failed at doing.
With state machines, such processing is well in the ballpark!
I have shown here lexing serial data on the fly. I match keywords as the final char arrives where buffer-then-match just begins the keyword match part. I was doing that starting in 81 with typed user entries. Don't waste cycles waiting for data to pile up!
You need more.
